Part Number: PCM6260-Q1
Hi team,
For PCM6260-Q1, for example, single-ended input amplitude is V=2V, differential input amplitude is V=1V, so actual input voltage=(V+) - (V-)=2V.
From our understanding, the ADC conversion results should be the same for single-ended and differential input. But the test results show single-ended is 6dB more than differential.
Is there any like internal gain setting difference? Could you please help to explain the reason?
