OPA1632: Stability of cascade amplifiers
Part Number: OPA1632
How to determine stability of cascaded opamps using TINA TI?
  • Hi Vinay,
    I am not able to see the image you attached. Can you try reattaching the image?
    Nick
  • Hi Vinay,
    In order to check the stability of cascaded amplifiers, you will need to check the stability of each stage with the other stages connected to get the effects of the input and output loading.
    For example:
    Check the stability of the second stage with the first stage connected to simulate the input loading, as shown below
    Then check the stability of the first stage with the second stage connected to simulate the output loading, as shown below
    If both connections are stable, the system will be stable as well.
    Nick
