TLV320AIC3254 is powered with 1.8V.
I have analog signal conditioning that results in a single-ended analog signal with common mode dc bias of 0.9V.
Is there any issue with omitting the AC-coupling caps on TLV320AIC3254 IN1_L / IN1_R pins in this use-case?
Would any difference in voltage between my analog signal conditioning's 0.9V bias point and the TLV320AIC3254 bias point be gained up by the PGA, potentially saturating output, depending on gain level of PGA?
Is it possible to output TLV320AIC3254 common mode voltage to one of the analog pins?
