Part Number: PCM1821EVM
Other Parts Discussed in Thread: PCM1821, PCM4201, DRV134
Hi
PCM1821 transmits 32-bit two-channel data. The customer's product actually only has a mono signal. When the back-end MCU receives the I2S dual-channel data, it needs to discard one channel, which is very cumbersome to process. Can I ask if PCM1821 can be set to 16bit mono signal output? Or is there any recommendation for an Audio Codec with mono MIC IN or Line in, 16bit mono I2S output?
