Hi, Support Team
We saw the datasheet 6.3.7.1.6 have some question
6.3.7.1.6 Input Pin Short to VBAT_IN
A short to VBAT_IN fault occurs when the difference between the voltage measured for the VBAT_IN pin and the
input pin, ABS(VBAT_IN – INxx), is less than the threshold or both the VBAT_IN and INxx pin measured voltages
are above 11.7V. The threshold can be set by configuring DIAG_SHT_VBAT_IN, P1_R71_D[3:0].
When VBAT_IN is less than MICBIAS, false fault detections can exist based on the signal level of the INxx
pin. To minimize false detections there is also a separate debounce count for this condition set by configuring
VSHORT_DBNCE, P1_R74_D1.
if VBAT_IN voltage is setting 8V and MICBIAS also is 8V, The Codec could possible easy occurs fail?
have any side effect
if any suggestion, Please advise me.
Lawrence
