Other Parts Discussed in Thread: TPA3255, TAS5558, TAS5548, TAS5508C, TAS6584-Q1
The datasheet for the TAS5634 indicates that the minimum PWM frame rate for the device is 352Khz. It does not however describe anywhere what will happen if the PWM frame rate input to the IC is below this frequency. Does the TAS5634 have an internal oscillator that is PLL locked to the incoming PWM frame? What happens to the outputs of the TAS5634 if the PWM signal freezes? Are the limits on the PWM frame rate related in some way to bootstrap recharge. I am investigating driving the PWM inputs with a product other than the ICs suggested by TI. A better understanding of the processes involved with the TAS5634 would be helpful to ensure that a reliable system can be created and debugged.
All the best
Aidan
