TLV320AIC3204EVM-K: AGC:Audio compression curve
Part Number: TLV320AIC3204EVM-K
Hello, now I need to reduce the gain effect, that is, the compression curve as a whole. Do I only need to modify the parameters of AGC to achieve this? If not, what else should be changed? P1 is the current compression curve and P2 is the compression curve that needs to be achieved.
Parameter configuration of AGC parameters:
TLV320AIC3204EVM-K: About the AGC loop - Audio forum - Audio - TI E2E support forums
If it is convenient, you can tell me how to modify the parameters of AGC. Thank you very much!
Can you help to solve it
thanks
