The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
OPA1632: Dual supply op amp design method
Part Number: OPA1632
In TI book op amps for everyone , chapter 18 Designing Low voltage op circuits - in section 18.7 for single supply circuit design it is given that equation of straight line is to be followed.
What should be approach for dual supply op amp circuit? Similar or different
  • Hi Vinay,
    The same idea applies to a dual supply configuration. The swing of a device should be the same for a +5V supply and a +/-2.5V supply configuration. The ideas highlighted in the section you are referring to will be applicable in both.
    Ignacio
