TPA3138D2: Issues getting design through EMC conducted emission test.
Part Number: TPA3138D2
We have a PoE powered LoudSpeaker using the TDA3138D2 as the audio amplifier into a 4ohm load, in PBTL mode.
The test house has reported -
With the unit not emitting any audio, there is little noise near the limit, however whenever the amplifier is enabled, the noise generated and injected back down the Ethernet cable exceeds the higher Class A (higher) limit
This is pointing obviously at the Class D amplifier generating noise around 350kHz, which is escaping the unit.
I followed the datasheet with the circuit used, see attached, but i just cant get the design through testing. Any pointers as to what i might have done wrong or need to do? Sorry, having issues understanding how to add the schematic file, if this isn't readable, please provide an email and i'll send it over.
    I'll review your problem description and get back to you with further comments early next week.
    -Ivan Salazar
    Applications Engineer
    You can try adding an inductor or ferrite at the +12V line, before the decoupling capacitors, to try filtering down the switching noise of the Class-D from the supply.
    -Ivan Salazar
    Are there any app notes that deal with this and the solution. I'm surprised that there is no mention of this issue, which must be present on all designs using this device?
    I can add a LC filter on the 12V supply but id like to see more detail on this and perhaps approved solutions.
    Thanks.
    You may treat the design of a Class-D amplifier similar to that of a buck/boost converter. It follows similar principles of EMI/EMC due to PWM switching.
    I'll double check on previous documentation (although not specific for this amplifier) and share with you soon.
    -Ivan Salazar
