Part Number: PCM1681
Hi
I am using PCM1681. So when I am generating a sine wave from DAC, I am observing lot of noise. Datasheet mentions that there will be out of band noise at the output, which we need to remove using an external active LPF. I have used an LPF. At the output of LPF, the noise I am seeing at the output of DAC is eliminated and i can get clean waveform.
But, this much of noise is expected at the output of PCM1681?
- My sampling rate is 32khz. system clock-4.096M, BCK-1.024M
