Other Parts Discussed in Thread: LM5123-Q1
I am testing using TAS6584-Q1 2ea and LM5123-Q1.
Audio input uses TDM and output channels use 4 channels each, for a total of 8Ch.
Even if no signal is input to Audio Input, the following waveform is generated in SPK(OUT1).
If a sound source signal is input to Audio Input, a sound with noise is played.
The register settings are as follows.
Address 0x21, Data 0x14 / TDM Mode
Address 0x23, Data 0x0F / 32bit
Address 0x03, Data 0x44 / CH1, CH2 Play
I would like to ask for help on why a strange waveform is generated on the speaker side.
And additionally, please check if the register settings are correct.
