I have created a PCB where PCM5122 is used as follows;
- ATT2, ATT1, ATT0, MAST, AGNS, MODE1, MODE2, FLT, SCK pins are grounded.
- FMT and XSMT are high
- I have perfect 3.3V on analog & digital supply, 1.8 volts on LDOO (self regulated), -3.3V on charge pump output
- I am supplying a 24 bit 96 khz audio data with 6.144Mhz BCK. On the PCM input pins I can observe BCK, WS and Left Aligned Data (LSB aligned to the 1st clock).
However I am getting no output. Changed DAC several times. There seems no HW fault.
What am I missing?
