Dears,
The customer connects the pin2 SD/FAULT enabled amplifier IC through MCU IO, there is a Pop and Click sound in startup. The datasheet sheet describes Pop and Click Free Startup.
Dears,
I would recommend to set the node marked VMID2 to be a ground instead. For single ended audio we typically recommend having one of the inputs be the signal and the other be ground.
Ramsey
