TAS2505-Q1: [AM62x] external AMP TAS2505 output signal issue
Part Number: TAS2505-Q1
Hello TI
Our custom board connects to an external AMP  (MCASP1 -> TAS2505->Speaker).
As far as we know, our arch is a Bridge mode and we expect to see the output of SPKP/SPKM wave form pattern are opposit , we measured at (1) & (2).
However, now we see them have the same pattern as below. May you provide an explaination? If it is an issue, how to fix it?
  • Hi Paul
    This should be the Class AD modulation. And this modulation has large pop noise problem, we changes to Class BD modulation for the new developing parts.
    Below picture shows a simple comparison for this two modulation type. Class AD reverse the PWM directly, so you would find a totally reversed P/M output. But Class BD reverse the audio input, then compare twice with the same Carrie, so not totally reversed PWM.
  • Hello Shadow
    We are using TAS2505TRGERQ1 part number, is it AD or BD? TAS2505TRGERQ1 P/M outputs are not reversed. please kindly confirm.
  • Hello Shadow
    1. FYI, we measured SPK P/M output wavefrom, one by one with oscilloscope,  SPK P + Commond ground of our custom board, and SPK M + Commond ground of our custom board.
    SPK P/M both have the same parttern waveform.
    2. May you guide how to check analog signal as in red line? when we play 2k , 5k tune song
  • Hi Paul
    It's BD.
    Need to have LC filter at both output, to test out the sine waveform. Like 10uH+0.47uF.
