Other Parts Discussed in Thread: PCM5101A,
Hi
I'm completely new to analog circuitry, I have connected a PCM5101A directly to a small speaker (250mW 8Ohm), which give way to low sound level.
Considering using the TPA6111A2 amplifier, but I'm just doing guesswork on how to connect the DAC output to the amp input. Both devices as powered by 3.3 v and a schematic showing the analog path (Left channel) from PCM5101A to the TPA6111A2 attached below.
Is it even close to correct?
PCM5101A: https://www.ti.com/product/PCM5101A
TPA6111A2: https://www.ti.com/product/TPA6111A2
