Other Parts Discussed in Thread: TAC5212, PCM5122, PCM5242, TAA5212, TAD5212
Dears,
we would use the TAC5212 for our systems. We have a digital input (I2S) and we would use dac to have an analog differential output to pilot a load.
we woud have different output signal frequency with fixed sampling frequency at 768Khz.
We need following output signal frequency:34Khz, 80Khz and 180 Khz but we have seen from datasheet that maximum output DAC frequency is 96KHz.
Is there any way to unlock a bigger output DAC freq than 96Khz?
We would use the TAC5212 with a Linux Debian SO. COuld you provide driver to use your codec with Linux?
Is this codec ALSA compliant? Could you provide additional software to control the TAC5212 through ALSA?
Thanks in advance
