PCM5101A: PCM5101A
Part Number: PCM5101A
After turning off XSMT (17 pin), I want to confirm the time it takes for OUTL (6 pin) to attenuate.
The datasheet states the following:
The soft attenuation ramp takes 104 samples.
I don't understand the interpretation of “soft attenuation ramp”. Is it correct to interpret that OUTL (6 pin) fully attenuates after 104 samples?
PCM510xA 2.1 VRMS, 112/106/100 dB Audio Stereo DAC with PLL and 32-bit, 384 kHz PCM Interface datasheet (Rev. C)
