TAS2572: Spread Spectrum Modulation (SSM) Clock Control
Part Number: TAS2572
While the datasheet explicitly mentions that the TAS2572 supports programmable clock Edge Rate Control (ERC) and Spread Spectrum Modulation (SSM), it does not list a specific user-accessible register bit (e.g., SSM_EN) in the detailed register map to directly enable or disable SSM manually.  What is the default SSM setting and how is it controlled?
