We are using TLV320AIC33 Codec with line inputs and line outputs.
We use operational amplifiers in the line outputs in order to increase the signal levels.
My question is that must we use external low pass filter in our line outputs for the out-of-band issues?
While first using this codec we thought this codec has internal audio filters.
Codec has some digital filters and analog reconstruction filter but i think an external filter is needed for out-of-band noise. Is that true?
I read some articles about out-of-band noise of audio DACs and my understanding, if it is true, is that the external low pass filters are necessary
in order to make true dynamic performance measurements such as THD+N, SNR or SINAD.
But i am suspicious about using a low pass filter in the circuit itself, not only for measurements.
In EVM kit of TLV320AIC33 there is no external filters on outputs.
At the moment we have a design without an external filter and our line outputs are noisy when looking with oscilloscope.(100mVpp noise on a 800mVpp sinus signal).
In the FFT plot this noise is seen between 100KHz and 500 KHz.
My main question is how big this out-of-band noise problem is?
Can i think this is not a problem because the noise is not in auido band?
or
Must use a sufficient external low pass filter in order not to have any problem?
Thanks.
Mustafa Sü
Digital Design Engineer
