DIT4192 master clock
Other Parts Discussed in Thread: DIT4192
I would like to provide the master clock for the DIT4192 directly from a clock distribution chip. But then SCLK, LRCLK and data coming from the ADC chip will have a delay of about 3ns compared with the direct clock signal because of a bus transceiver on the audio serial lines. In datasheet I find no information about the timing requirements of the master clock related to the audio serial input. Has someone experiences whether these 3ns offset could cause problems?
By the way, does someone know what exact function the separate master clock input has? Mainly I wonder what clock determines the clock quality of the AES output signal, the master clock, SCLK or LRCLK?
It would be very nice if someone could give me some more information please.
Best wishes
Ralf
  • Hi, Ralf,
    Interesting questions!
    Would it be possible for you to delay the data by 3 ns as well so everything is still time-aligned?
    -d2
  • Hi Don,
    thank you for your reply! Yes, I could send the master clock to a buffer like the other serial audio lines, too. But actually it would make no sense, using a high precision clock distribution fanout followed by a buffer. It makes the signal not better in that case, but maybe worse. If I got you right, your answer means: it would be better to time-align it, but it is not necessarily a problem, isn´t it?
    Essentially we are back at the question about what clock does determine the clock quality of the AES output. Maybe I should not care about the master clock quality at the DIT, at least not about this one additional buffer.
    Ralf
