I'm having a problem with this codec. When I overdrive the ADC inputs, there is feedthrough to the DAC outputs and hence speaker noise/distortion. What is the best way to fix this issue? Is there something in the setup?
Hi, Rustin,
What do you mean "overdrive the ADC inputs?"
Are you exceeding the Absolute Maximum Voltage on those pins from the table in the data sheet?
-d2
