Question on TPA2012D2
Other Parts Discussed in Thread: TPA2012D2EVM, TPA2012D2
Is there a way to calculate the input voltage (non clipping) and the max input voltage value?
My test result shows a sudden increase in power when input signal at the Class D Amp IC increase from 600mVp-p to 1.2Vp-p.
The power is measured (codec+Class D Amp+ Speaker circuit) at Class-D Amp
Input signal          Power measured
150mVp-p              1.2W
210mVp-p              1.44W
330mVp-p              2.28W
600mVp-p              3.48W
1.2Vp-p               6.36W
2.25Vp-p              8.52W
If I disconnect Class D Amp and Speaker from Codec IC.
Codec maintain at 1.2W power when increase from 150mVp-p to 2.25Vp-p.
Therefore,the increase of power is confirmed coming from Class-D Amp and Speaker side.
Is this behaviour correct?
This test is done with Gain of 24dB, Vdd @ 5V, impedance 4ohm.
