LME49724 ENABLE Mode
Other Parts Discussed in Thread: LME49724
Hello.  I'm using LME49724 in a design, and I'm finding that when the chip is disabled by bringing pin 7 to Vee, the output pins rise to the rail voltages.  Is this normal?
Specifically, Pin 4 (Vout-) displays a voltage equal to approximately Vee + .6V, and pin 5 (Vout+) displays a voltage equal to approximately Vcc - .6V.
I would expect the output pins to fall to zero when the chip is disabled.
FWIW, Vocm is tied directly to ground.
Thanks!
