TLV320AIC3204 Stereo Configuration
Other Parts Discussed in Thread: TLV320AIC3204
Hi all,
I have the CC85XX Headset Developpement Kit and I'm trying to configure my AIC3204 codec to separate left and right channels (IN1_L and IN1_R).
I tried to use the "Design and Configuration Guide for the TLV320AIC3204" in the audio device customization in the Purepath Wireless Configurator, but both channels are always mixed.
What have I to change to separate the channels ?
Thank you very much.
Mathilde
  • Hi Mathilde,
    I will review the register configuration and I will answer as soon as possible.
    Thank you.
    Luis Fernando Rodríguez S.
  • Hi Mathilde,
    In the TLV320AIC3204 GUI, there're some typical recording configurations. Regarding your application, I found this script that could help you. Could you take a look of it please?
    # High Performance Stereo Recording
    # PowerTune mode PTM_R4 is used for high
    # performance 16-bit audio.
    # For normal USB Audio, no hardware change
    # is required.
    # If using an external interface, SW2.4 and
    # SW2.5 of the USB-ModEVM must be set to
    # HI and clocks can be connected to J14 of
    # the USB-ModEVM.
    # IN1L/R is routed to the LADC/RADC in a
    # single-ended manner.
    # Software Reset
    # Select Page 0
    w 30 00 00
    # Initialize the device through software reset
    w 30 01 01
    # Clock Settings
    # The codec receives: MCLK = 11.2896 MHz,
    # BLCK = 2.8224 MHz, WCLK = 44.1 kHz
    # Select Page 0
    w 30 00 00
    # NADC = 1, MADC = 2
    w 30 12 81 82
    # Signal Processing Settings
    # Select Page 0
    w 30 00 00
    # Set the ADC Mode to PRB_P1
    w 30 3d 01
    # Initialize Codec
    # Select Page 1
    w 30 00 01
    # Disable weak AVDD in presence of external
    # AVDD supply
    w 30 01 08
    # Enable Master Analog Power Control
    w 30 02 00
    # Select ADC PTM_R4
    w 30 3d 00
    # Set the input powerup time to 3.1ms (for ADC)
    w 30 47 32
    # Set the REF charging time to 40ms
    w 30 7b 01
    # Recording Setup
    # Select Page 1
    w 30 00 01
    # Route IN1L to LEFT_P with 20K input impedance
    w 30 34 80
    # Route Common Mode to LEFT_M with impedance of 20K
    w 30 36 80
    # Route IN1R to RIGHT_P with input impedance of 20K
    w 30 37 80
    # Route Common Mode to RIGHT_M with impedance of 20K
    w 30 39 80
    # Unmute Left MICPGA, Gain selection of 6dB to make channel gain 0dB
    # Register of 6dB with input impedance of 20K => Channel Gain of 0dB
    w 30 3b 0c
    # Unmute Right MICPGA, Gain selection of 6dB to make channel gain 0dB
    w 30 3c 0c
    # Select Page 0
    w 30 00 00
    # Power up LADC/RADC
    w 30 51 c0
    # Unmute LADC/RADC
    w 30 52 00
    Thank you.
  • Thank you verry much ! Everything is ok now !
    Thank you again.
    Best regards.
    Mathilde
