DRC : AIC3204 vs tpa2016d2
Other Parts Discussed in Thread: TPA2016D2Hi, I am using the AIC3204 codec with the TPA2016D2 Audio amplifier. Is there any difference between the AIC3204 and the TPA2016D2 DRC performaces ? My taget audio application is focused on voice. Thanks. Nicolas
  • Hi Nicolas,
    Basically the DRC performance is similar between these devices as they have several programmable parameters used to adjust the desired performance. One notorious difference is the number of available gain settings, being the one of the TPA2016D2 wider, while the AIC3204 has less options.  I would recommend you to take a look to the TPA2016 datasheet and the AIC3204 Reference guide. There is plenty information about AGC configuration and usage.
      -Diego Meléndez López
       Audio Applications Engineer
