PCM1794A Noise@260kHz and 125MHz
Other Parts Discussed in Thread: PCM1794A
My customer is evaluating PCM1794A on the typical application circuit.
They has a trouble of noise, and we're checking the cause.
The noise is seen on the output of the I/V amp and Diff/Signal amp.
The frequency of the noise is 260kHz and 125MHz.
For the measurement circuit and waveforms and CLK freq etc, please refer the attached file.
The following is my question.
・Does the PCM1794A have the oscillator(i.e. PLL) regarding 260kHz of 125MHz?
Please let me know if you have the supposed cause or the experiment.
PCM1794A.xlsx
Thanks and Regards,
Kuramochi
  • Hi, Kuramochi-san,
    It will take us some time to investigate this with you. I expect about a week to get some results.
    Please let us know in the meanwhile if you find any more information before then.
    -d2
  • Hi Kuramochi-san,
    Thank you for the detailed waveform and schematic with HW control settings. Is this noise the only output you get or is this noise that is on top of your signal? Have you confirmed that your data coming in is right justified? The standard setting (your current setting) is right justified PCM data. have you tried this with a known good audio source?
    There are no internal supplies that create 260 kHz or 125 MHz signals/noise. Does this noise happen when no audio is played, and at all times?
    Justin
