PCM2706 strange sound
Other Parts Discussed in Thread: PCM2706
Dear Sir
We uses PCM2706 Audio DAC for USB MP3 player.
So far we encountered a problem need your help to clarify. below is our schematic file
http://www.seawalk.com.tw/0000/2.html
When we turn on the system power,  PCM2706 has strange sound, we checked the waveform and found some strange as below video.
www.seawalk.com.tw/.../2.1.mp4
the situation only happens in the beginning 5 minutes of turning on power, then it will disappear
Moreover we ran EVT 500kits only 18kits has this issue.
May you give me some suggestion of this problem? Thanks,
  • Hi Passerby,
    Your schematic seems to be fine.
    I have viewed the video you shared, it seems that the signal is gone and then it comes back, but the transition is almost immediate.
    I think the problem could be on the digital section of the system. As the signal is abruptly interrupted there is a chance that a data packet from the USB host is lost or corrupted. Perhaps there is some kind of problem with the clock signals or the digital pairing.
    The crystal resonator circuitry is connected close to the PCM2706?
    VDD (Pin 21) is output from the internal voltage regulator, there is not an external supply voltage at VCC_3V3, right?
    -Ivan Salazar
    Texas Instruments
  • Dear Sir,
    thanks for your reply.
    (1) Yes, the crystal is connected close to the PCM2706.
    (2) VDD(Pin21) we have used a buck 3.3v connect to this pin (VCC_3V3). is this a problem?
    Thanks.
  • Passerby,
    PCM2706 in BUS-powered internally generate its 3.3V supply rails from the 5V Vbus. So there is no need to connect an external supply voltage to VDD, VCCL, VCCR and VCCP. Although I don't think this is really the cause of the noise problem.
    Is there a way you could inspect the digital USB input signal to be sure that the signal reaches completely and not distorted to the PCM2706?
    -Ivan Salazar
    Texas Instruments
  • Dear Ivan,
    That is digital USB input signal , I can not inspect it . Do you have any other suggestion for this issue? Thanks.
  • Dear Sir,
    Any suggestion would be highly appreciated, Thanks.
  • Passerby,
    Sorry for the delayed response.
    I think the problem must be on the digital side, some kind of synchronization issue as this seems to be solved after 5 minutes.
    Could you please share the layout? This is just to take a look how is it all connected. You can send it to my mail address ivan.salazar@ti.com if you don't want to upload it to the forum.
    The video you uploaded shows a 1-kHz signal where a full cycle of the signal is missing.
    Is this behavior the same for any signal frequency? What I mean is, if you use a higher/lower frequency, is it missing a full cycle of the signal, too?
    -Ivan Salazar
    Texas Instruments
