Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
PCM1753 SNR Iissue
Other Parts Discussed in Thread: PCM1753
Hi Team,
The customer is using PCM1753. In his design, he tests the SNR value and it is only 72dB. He does a test. He removes the LEFT_LPF and RIGHT_LPF circuit ,and connects two 10uF capacitance to 7 pin and 8 pin. That is  the output for 7 pin and 8 pin is directly to the headphone.  Finally, he can hear music from the headphone , but there is a lot of noise. Look the  attachment.
What is the reason? Is the schematic correct?  How to solve the issue?
