Dear audio expert,
Could you please help double check whether TI have similar/same function audion converter with CS4344 and CS5343? thanks.
Best Regards
Iven Xu
Dear audio expert,
Best Regards
Iven Xu
Hi Luis,
Thanks for your response.
I have double checked the datasheet of the parts you recommended, I found it is too complicated comparing to CS5343/CS4344.
1, for the DAC: how about PCM1754? as you can see CS4344 is very simple only with the digital input and analog output.
2, for the ADC: how about the PCM1808?
Best Regards
Iven Xu
