Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
About TAS2521 – Gain setting and, THD+N data on datasheet
(1) Regarding to the gain setting, I have a question.
My customer is setting following gain volume and is asking about appropriately gain setting.
(a) DAC Channel Digital Volume Control Register (Page0, Reg 0x41) -> Their setting value is maximum(+24dB).
(b) Speaker Amplifire Volume Control 1 (Page1, Reg 0x2E) -> They are using for main volume control.
(c) Speaker Amplifire Volume Control 2 (Page1, Reg 0x30) - > Their setting value is 6dB(0x01).
*I think that (c) Speaker Amplifire Volume is used for class-D amp gain and it depends on customer’s application.
Also this value should be fixed.
*Should (a)DAC Channel Digital Volume be set to maximum? Or how can they set the best setting?
(2) Regarding to Figure 4-5(THD+N vs 8ohm speaker power) on datasheet page 15, I have a question.
Do you have a THD+N data at Gain=6dB from output power=0.5W?
Tao_2199
  • Hi Tao,
    Regarding the gain settings: You could use a fixed value at the Speaker Amplifier Volume Control 2 (Class D volume) because this control changes in bigger steps. DAC Channel Digital Volume Control and Speaker Amplifier Volume Control 1 have smaller steps; you could fix the DAC Channel Digital Volume Control gain and use the Volume Control 1 as volume control.
    I will take a look at the THD+N plot and come back with comments later.
    -Ivan Salazar
    Texas Instruments
  • Hello Ivan,
    Thank you for reply.
    Regarding to the setting value of DAC Channel Digital Volume Control, I have a question.
    You mentioned that you could fix the DAC Channel Digital Volume Control gain and use the Volume Control 1 as volume control.
    In this case, what this setting value do you recommend?
    Maximum or Middle value ? Or it depends on customer’s application?
    Tao_2199
  • Hi Tao,
    The gain setting depends on customer application.
    -Ivan Salazar
    Texas Instruments
  • Hello Ivan,
    About THD+N data (@Gain=6dB),
    Would you let me about the current status ?
    Tao_2199
  • Hi Tao,
    The THD+N plot is stopped at that level because the output can't go higher in power at that specified configuration and load.
    -Ivan Salazar
    Texas Instruments
