Hi E2E,
My customer is using the LME49721 in a non-inverting configuration with resistors, caps, and a digital potentiometer in the feedback. The variable gain stage is causing the THD+N ratio to slowly rise up as it gets closer to the clip point.
If we remove the digital potentiometer and use a fixed gain, the THD+N curve looks much like the datasheet (see below)
If we remove the digital potentiometer and use a voltage follower, we see a bump before the rise.
If we use the original circuit with the digital potentiometer, this bump gets worse.
Do we have any thoughts on what might be causing this bump?
-Sam
