PCM1753: Pop Noise issue
Part Number: PCM1753
Other Parts Discussed in Thread: PCM5121, PCM5100A, PCM1774
Dear Technical Suppot Team,
I have an issue of pop noise on PCM1753 when power-on and power-off(on⇒off⇒on⇒off⇒on・・・).
This is old device. Could you tell me recommend devices pop noise is improved ?
ttd
  • Hi, Ttd,
    What is the sequence followed for the power on/off process?. You can try enabling the Soft Mute function to perform a soft transition when muting the part before powering down to avoid pop noise.
      -Diego Meléndez López
       Audio Applications Engineer
  • Dear Diego Meléndez López,
    Thank you for your reply.
    I check PCM5121/22 and PCM5100A/01A/02A.
    These datasheet shows pop-free solution when power-down.
    How is the power on ? Do they avoid pop noise when power on?
    Thank you for your reply. I'd like to try it before power down.
    ttd
    Sorry I have a mistake of part number.
    Exact number is PCM1774.
    By the way , Slow power up/down ramp time reduce the pop noise,right?
    If it is yes , do you know the effective ramp up/down time ?
    ttd
