Part Number: PCM1807
In a recent application we have implemented a PCM1807 converter operated in slave mode.
Driving the left channel only with 3Vpp, the converter has full scale output on left out as expected. The right channel is at noise level as it is not driven in this condtion.
When we increase the drive level with 3 dB ( slightly clipping the left channel ) the right channel jumps from -85 to-3dBfs and delivers a heavy distorted
version of the signal which is driving the left channel. I increased the series resistor at the inputs to 4700 Ohms which gives no improvement.
Even when floating the right channel the effect occurs, so this is not happening in the drive stage but in the converter input stage or modulator.
Is there any solution to work around this?
