Hi there,
We are considering using opa1678 as preamp of a pvdf audio sensor. Since there exist silver migration we do not want to put bias voltage to pvdf and thus figure35 in the datasheet is a good start.
1. With above R5&R6 connection, there will be a 1/2Vs+ voltage to bias piezo.
The pvdf film we are using does not need a bias voltage which leads to silver migration. So is it OK to just remove above R5&R6 to remove bias voltage?
2.Could you provide an example to connect the opa1678 outputs to an audio ADC. We have studied many audio ADCs and they only accept single-end voltage. But in above case I think it outputs negative voltage as well.
B.R.
