LM1894: How to Improve the High Frequency Gain of LM1894
Part Number: LM1894
按照参考设计电路:
1.将R1:R2设置成800:200 的时候,C10默认电压为1.4V 动态范围较大,最高可以到3.3V(1.4V-3.3V)低频增益特性很好。但是高频增益不足。
2.为了提高高频的增益,降低R1:R2的比值为500:500。 这时高频的增益会变好。但是C10的默认的电压会变高。为2.2V。动态范围为  2.2V-3.3V,导致动态范围比较小。  这样提高了高频响应,低频特性变差。
我的需求:
1.在我降低R1:R2比值的时候,不要提高C10的默认电平,或者说降低C10的默认点平。
2.或者在现有的电路上如何提高高频的增益
我的应用里面没有FM 没有L8  R8 CL。
C10调参为4.7uF
C12调参为4.7nF
According to the reference design circuit:
1. When R1:R2 is set to 800:200, the default voltage of C10 is 1.4V. The dynamic range of C10 is large, and the low-frequency gain characteristic of C10 can be up to 3.3V (1.4V-3.3V) is very good. But the high frequency gain is insufficient.
2. In order to improve the high frequency gain, reduce the ratio of R1:R2 to 500:500. At this point, the high-frequency gain will improve. But the default voltage of C10 will be higher. It's 2.2V. The dynamic range is 2.2V-3.3V, which results in a smaller dynamic range. This improves the high-frequency response and makes the low-frequency characteristics worse.
My needs:
1. When I reduce the ratio of R1 to R2, don't raise the default level of C10, or lower the default level of C10.
2. Or how to improve high-frequency gain on existing circuits
There is no FM in my application and no L8 R8 CL.
C10 parameter adjustment is 4.7uF
C12 parametric adjustment is 4.7nF
    Welcome to e2e.
    I think the behavior your're seeing is the expected, based on data sheet information.
    Perhaps you can try to adjust the value of the capacitors of the control path signal or the capacitors from the integrator (C3 & C12).
    In addition, I would like to highlight that this device is NRND (Not Recommended for New Designs), although still active; we suggest to look into our product portfolio for a replacement.
    Support for newer devices is better as there is more information available and also there are evaluation tools, like EVMs.
    -Ivan Salazar
    Applications Engineer - Low Power Audio & Actuators
  • Hi
    Thanks for your support!
    which capacitors of control path is most sensitive? C5?C6? C9?
    in my opinion,add the value of C5 C6 will add DC-bias of C10.
    Debing
  • Debing,
    Unfortunately I don't have any tool to test this so I couldn't tell for sure. I would just try with different values on those caps.
    -Ivan Salazar
    Applications Engineer - Low Power Audio and Actuators
