Part Number: LME49726
Other Parts Discussed in Thread: TINA-TI
Need to confirm setup for 5 volt single supply low gain value non inverting. Please comment on our approach and if it is correct and not what we need to do. Thank you.
Hi Devon,
The schematic seems to be correct. Please see the attached simulation results (verify component values as I can't clearly see some of them).
You can run any additional simulations using the TINA-TI model available in LME49726 product folder, under Tools & Software.
Are you using polarized capacitors at the inputs? If you do, these might need to be flipped as the positive terminal would be currently be connected to the device inputs.
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
