Hi professional,
My customer has questions for TAS5782M's minimum recommended Lout
1.
What is occur under short-circuit if we use lower value Coil than datasheet recommendation.
2.
Is there difference regarding minimum inductor value between BTL mode and PBTL mode?
3.
As this E2E thread mentioned, Our class D amp assumed 20% tolerance for minimum output load. Is this way of thinking applicable to minimum output inductor?
For example, minimum value is 1uH, however 0.8uH is acceptable.
I'm waiting your answer.
Kazuki Kuramochi
