TPA3221: RC Passive Low Pass Filter
Part Number: TPA3221
The RC passive low pass filter is applied to the input stage on TPA3221EVM, so could you please tell me whether that is necessary ?
Kato
  • Kato,
    Robert will follow up TAS3221 realted question soon.
    Rdgs,
    Matthew
  • Hi Matthew-san,
    Thank you for your reply.
    I am looking forward to hearing from Robert-san.
    Kato
    kato-s@macnica.co.jp
  • Hi Sadanori,
    the RC low pass filters at the inputs definitely make sense. They help to prevent the swichting noise from coupling back into the inputs via stray capacitance. I wouldn't omit them.
    Kai
  • Hi Kai-san,
    Thank you for your comment.
    If RC low pass filter should be applied to the input stage on TPA3221, this content should be mentioned in TPA3221 data sheet, so I would like to know the reason why this content isn't mentioned.
    Kato
  • Hi Sadanori,
    having passive low pass filtering in an audio signal path at several places is good design practise. In extended professional audio mixing consoles you can see it at each OPAmp stage sometimes. But actually there's no need for it. It only improves the performance. Here it's the same, it improves the performance.
    In this EVM the input signal lines seem to be much longer than usual. This makes the signal lines more susceptible against capacitive stray coupling. This might be the reason why the RC low pass filtering was added here.
    I do always have lots of passive band pass filtering in my audio circuits, even when others say it is overkill. But it allows me to achieve a very professional performance.
    Kai
  • Hi Kai-san,
    Thank you for the information.
    I also agree with your opinion.
    Kato
