Other Parts Discussed in Thread: PCM5100A, , PCM5101A
Hi Sir
I saw PCM1754DBQR is used for 3.3V logic level
May I know TI have similar solution for 1.8V logic level
Hi Kai,
That depends on what you are using the amplifier for. The PCM5101A has better output load capability than the PCM1754, so it can drive as low as 1kΩ. It also has better out of band noise performance, and so it does not need a 2nd order active filter.
Paul
