Other Parts Discussed in Thread: TAS5782M
Hi Expert,
I'm facing an I2C communication problem.
The MCU is transmitting registers directly to TAS5782MEVM's test-points(SCL,SDA) without PPCMB and PPC3.
Registers were dumped by PPC3(Speaker configuration is "Stereo 2.2 L/R").
There is no delay between the registers, and it transmits continuous.
Either of device does not return acknowledgement at one resister on the sequence.
But when I transmit only problem resister to device, it return acknowledgement normally.
1. What is the probable cause?
2. My program is the MCU transmits same register values alternately to each device.
Is this sequence right?
Ex.
0x90, 0x1A, 0x00
0x92, 0x1A, 0x00
0x90, 0x1B, 0x00
0x92, 0x1B, 0x00
0x90, 0x1C, 0x7f
3. This is another question.
Now I'm connecting I2S data line to only SDIN1.
Is this connection right? Or I should connect I2S data line to SDIN1 and SDIN2 in parallel?
Keigo Iwahori.
const unsigned char registers[][2] = {
//program memory
{ 0x00, 0x00 },
{ 0x7f, 0x00 },
{ 0x02, 0x11 },
{ 0x01, 0x11 },
{ 0x00, 0x00 },
{ 0x00, 0x00 },
{ 0x00, 0x00 },
{ 0x00, 0x00 },
{ 0x03, 0x11 },
{ 0x2a, 0x00 },
{ 0x25, 0x18 },
{ 0x0d, 0x10 },
{ 0x02, 0x00 },
//Enable sub channel
// YM host buffer
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
//prm_nosub
{ 0x00, 0x1d },
{ 0x28, 0x00 },
{ 0x29, 0x00 },
{ 0x2a, 0x00 },
{ 0x2b, 0x00 },
//Sample rate update
{ 0x00, 0x00 },
{ 0x7f, 0x00 },
{ 0x02, 0x80 },
{ 0x00, 0x00 },
{ 0x7f, 0x00 },
// speed 03-48k 04-96k
//dynamically reading speed
{ 0x22, 0x03 },
{ 0x00, 0x00 },
{ 0x7f, 0x00 },
{ 0x02, 0x00 },
//Coefficients
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1a },
{ 0x08, 0x7f },
{ 0x09, 0xff },
{ 0x0a, 0xff },
{ 0x0b, 0xff },
{ 0x0c, 0x00 },
{ 0x0d, 0x00 },
{ 0x0e, 0x00 },
{ 0x0f, 0x00 },
{ 0x10, 0x00 },
{ 0x11, 0x00 },
{ 0x12, 0x00 },
{ 0x13, 0x00 },
{ 0x14, 0x00 },
{ 0x15, 0x00 },
{ 0x16, 0x00 },
{ 0x17, 0x00 },
{ 0x18, 0x00 },
{ 0x19, 0x00 },
{ 0x1a, 0x00 },
{ 0x1b, 0x00 },
{ 0x1c, 0x7f },
{ 0x1d, 0xff },
{ 0x1e, 0xff },
{ 0x1f, 0xff },
{ 0x20, 0x00 },
{ 0x21, 0x00 },
{ 0x22, 0x00 },
{ 0x23, 0x00 },
{ 0x24, 0x00 },
{ 0x25, 0x00 },
{ 0x26, 0x00 },
{ 0x27, 0x00 },
{ 0x28, 0x00 },
{ 0x29, 0x00 },
{ 0x2a, 0x00 },
{ 0x2b, 0x00 },
{ 0x2c, 0x00 },
{ 0x2d, 0x00 },
{ 0x2e, 0x00 },
{ 0x2f, 0x00 },
{ 0x00, 0x1c },
{ 0x6c, 0x7f },
{ 0x6d, 0xff },
{ 0x6e, 0xff },
{ 0x6f, 0xff },
{ 0x70, 0x00 },
{ 0x71, 0x00 },
{ 0x72, 0x00 },
{ 0x73, 0x00 },
{ 0x74, 0x00 },
{ 0x75, 0x00 },
{ 0x76, 0x00 },
{ 0x77, 0x00 },
{ 0x78, 0x00 },
{ 0x79, 0x00 },
{ 0x7a, 0x00 },
{ 0x7b, 0x00 },
{ 0x7c, 0x00 },
{ 0x7d, 0x00 },
{ 0x7e, 0x00 },
{ 0x7f, 0x00 },
{ 0x00, 0x1d },
{ 0x08, 0x7f },
{ 0x09, 0xff },
{ 0x0a, 0xff },
{ 0x0b, 0xff },
{ 0x0c, 0x00 },
{ 0x0d, 0x00 },
{ 0x0e, 0x00 },
{ 0x0f, 0x00 },
{ 0x10, 0x00 },
{ 0x11, 0x00 },
{ 0x12, 0x00 },
{ 0x13, 0x00 },
{ 0x14, 0x00 },
{ 0x15, 0x00 },
{ 0x16, 0x00 },
{ 0x17, 0x00 },
{ 0x18, 0x00 },
{ 0x19, 0x00 },
{ 0x1a, 0x00 },
{ 0x1b, 0x00 },
{ 0x58, 0x00 },
{ 0x59, 0x00 },
{ 0x5a, 0x00 },
{ 0x5b, 0x01 },
{ 0x6c, 0x00 },
{ 0x6d, 0x00 },
{ 0x6e, 0x00 },
{ 0x6f, 0x00 },
{ 0x70, 0x00 },
{ 0x71, 0x00 },
{ 0x72, 0x00 },
{ 0x73, 0x00 },
{ 0x74, 0x00 },
{ 0x75, 0x80 },
{ 0x76, 0x00 },
{ 0x77, 0x00 },
{ 0x78, 0x00 },
{ 0x79, 0x00 },
{ 0x7a, 0x00 },
{ 0x7b, 0x00 },
{ 0x7c, 0x00 },
{ 0x7d, 0x80 },
{ 0x7e, 0x00 },
{ 0x7f, 0x00 },
{ 0x00, 0x1e },
{ 0x08, 0x00 },
{ 0x09, 0x00 },
{ 0x0a, 0x00 },
{ 0x0b, 0x00 },
{ 0x0c, 0x00 },
{ 0x0d, 0x00 },
{ 0x0e, 0x00 },
{ 0x0f, 0x00 },
{ 0x10, 0x00 },
{ 0x11, 0x00 },
{ 0x12, 0x00 },
{ 0x13, 0x00 },
{ 0x4c, 0x00 },
{ 0x4d, 0x80 },
{ 0x4e, 0x00 },
{ 0x4f, 0x00 },
{ 0x7c, 0x00 },
{ 0x7d, 0x20 },
{ 0x7e, 0xc4 },
{ 0x7f, 0x9c },
{ 0x00, 0x1f },
{ 0x10, 0x7f },
{ 0x11, 0xff },
{ 0x12, 0xff },
{ 0x13, 0xff },
{ 0x24, 0x00 },
{ 0x25, 0x20 },
{ 0x26, 0xc4 },
{ 0x27, 0x9c },
{ 0x30, 0x7f },
{ 0x31, 0xff },
{ 0x32, 0xff },
{ 0x33, 0xff },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x23 },
{ 0x14, 0x00 },
{ 0x15, 0x00 },
{ 0x16, 0x00 },
{ 0x17, 0x01 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x11 },
{ 0x58, 0x3a },
{ 0x59, 0x2a },
{ 0x5a, 0x1f },
{ 0x5b, 0x69 },
{ 0x5c, 0xc5 },
{ 0x5d, 0xd5 },
{ 0x5e, 0xe0 },
{ 0x5f, 0x97 },
{ 0x60, 0x3a },
{ 0x61, 0x2a },
{ 0x62, 0x1f },
{ 0x63, 0x69 },
{ 0x64, 0x65 },
{ 0x65, 0x0d },
{ 0x66, 0x96 },
{ 0x67, 0xaa },
{ 0x68, 0xac },
{ 0x69, 0x5f },
{ 0x6a, 0xfb },
{ 0x6b, 0x8f },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x11 },
{ 0x6c, 0x65 },
{ 0x6d, 0x86 },
{ 0x6e, 0xf6 },
{ 0x6f, 0xdc },
{ 0x70, 0x9a },
{ 0x71, 0x79 },
{ 0x72, 0x09 },
{ 0x73, 0x24 },
{ 0x74, 0x65 },
{ 0x75, 0x86 },
{ 0x76, 0xf6 },
{ 0x77, 0xdc },
{ 0x78, 0x62 },
{ 0x79, 0xc2 },
{ 0x7a, 0x7f },
{ 0x7b, 0x21 },
{ 0x7c, 0xaf },
{ 0x7d, 0x69 },
{ 0x7e, 0x22 },
{ 0x7f, 0xd0 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x12 },
{ 0x08, 0x7f },
{ 0x09, 0xff },
{ 0x0a, 0xff },
{ 0x0b, 0xff },
{ 0x0c, 0x00 },
{ 0x0d, 0x00 },
{ 0x0e, 0x00 },
{ 0x0f, 0x00 },
{ 0x10, 0x00 },
{ 0x11, 0x00 },
{ 0x12, 0x00 },
{ 0x13, 0x00 },
{ 0x14, 0x00 },
{ 0x15, 0x00 },
{ 0x16, 0x00 },
{ 0x17, 0x00 },
{ 0x18, 0x00 },
{ 0x19, 0x00 },
{ 0x1a, 0x00 },
{ 0x1b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x12 },
{ 0x1c, 0x7f },
{ 0x1d, 0xff },
{ 0x1e, 0xff },
{ 0x1f, 0xff },
{ 0x20, 0x00 },
{ 0x21, 0x00 },
{ 0x22, 0x00 },
{ 0x23, 0x00 },
{ 0x24, 0x00 },
{ 0x25, 0x00 },
{ 0x26, 0x00 },
{ 0x27, 0x00 },
{ 0x28, 0x00 },
{ 0x29, 0x00 },
{ 0x2a, 0x00 },
{ 0x2b, 0x00 },
{ 0x2c, 0x00 },
{ 0x2d, 0x00 },
{ 0x2e, 0x00 },
{ 0x2f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x12 },
{ 0x30, 0x7f },
{ 0x31, 0xff },
{ 0x32, 0xff },
{ 0x33, 0xff },
{ 0x34, 0x00 },
{ 0x35, 0x00 },
{ 0x36, 0x00 },
{ 0x37, 0x00 },
{ 0x38, 0x00 },
{ 0x39, 0x00 },
{ 0x3a, 0x00 },
{ 0x3b, 0x00 },
{ 0x3c, 0x00 },
{ 0x3d, 0x00 },
{ 0x3e, 0x00 },
{ 0x3f, 0x00 },
{ 0x40, 0x00 },
{ 0x41, 0x00 },
{ 0x42, 0x00 },
{ 0x43, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x12 },
{ 0x44, 0x01 },
{ 0x45, 0xad },
{ 0x46, 0x62 },
{ 0x47, 0x39 },
{ 0x48, 0x01 },
{ 0x49, 0xad },
{ 0x4a, 0x62 },
{ 0x4b, 0x39 },
{ 0x4c, 0x01 },
{ 0x4d, 0xad },
{ 0x4e, 0x62 },
{ 0x4f, 0x39 },
{ 0x50, 0x69 },
{ 0x51, 0xab },
{ 0x52, 0x4c },
{ 0x53, 0xad },
{ 0x54, 0xa5 },
{ 0x55, 0xf3 },
{ 0x56, 0xdd },
{ 0x57, 0xc0 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x12 },
{ 0x58, 0x02 },
{ 0x59, 0x04 },
{ 0x5a, 0x14 },
{ 0x5b, 0x21 },
{ 0x5c, 0x02 },
{ 0x5d, 0x04 },
{ 0x5e, 0x14 },
{ 0x5f, 0x21 },
{ 0x60, 0x02 },
{ 0x61, 0x04 },
{ 0x62, 0x14 },
{ 0x63, 0x21 },
{ 0x64, 0x67 },
{ 0x65, 0x5b },
{ 0x66, 0x38 },
{ 0x67, 0x43 },
{ 0x68, 0xa9 },
{ 0x69, 0x39 },
{ 0x6a, 0x3e },
{ 0x6b, 0xf5 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x12 },
{ 0x6c, 0x7f },
{ 0x6d, 0xff },
{ 0x6e, 0xff },
{ 0x6f, 0xff },
{ 0x70, 0x00 },
{ 0x71, 0x00 },
{ 0x72, 0x00 },
{ 0x73, 0x00 },
{ 0x74, 0x00 },
{ 0x75, 0x00 },
{ 0x76, 0x00 },
{ 0x77, 0x00 },
{ 0x78, 0x00 },
{ 0x79, 0x00 },
{ 0x7a, 0x00 },
{ 0x7b, 0x00 },
{ 0x7c, 0x00 },
{ 0x7d, 0x00 },
{ 0x7e, 0x00 },
{ 0x7f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x13 },
{ 0x08, 0x7f },
{ 0x09, 0xff },
{ 0x0a, 0xff },
{ 0x0b, 0xff },
{ 0x0c, 0x00 },
{ 0x0d, 0x00 },
{ 0x0e, 0x00 },
{ 0x0f, 0x00 },
{ 0x10, 0x00 },
{ 0x11, 0x00 },
{ 0x12, 0x00 },
{ 0x13, 0x00 },
{ 0x14, 0x00 },
{ 0x15, 0x00 },
{ 0x16, 0x00 },
{ 0x17, 0x00 },
{ 0x18, 0x00 },
{ 0x19, 0x00 },
{ 0x1a, 0x00 },
{ 0x1b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x13 },
{ 0x1c, 0x7f },
{ 0x1d, 0xff },
{ 0x1e, 0xff },
{ 0x1f, 0xff },
{ 0x20, 0x00 },
{ 0x21, 0x00 },
{ 0x22, 0x00 },
{ 0x23, 0x00 },
{ 0x24, 0x00 },
{ 0x25, 0x00 },
{ 0x26, 0x00 },
{ 0x27, 0x00 },
{ 0x28, 0x00 },
{ 0x29, 0x00 },
{ 0x2a, 0x00 },
{ 0x2b, 0x00 },
{ 0x2c, 0x00 },
{ 0x2d, 0x00 },
{ 0x2e, 0x00 },
{ 0x2f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x13 },
{ 0x30, 0x7f },
{ 0x31, 0xff },
{ 0x32, 0xff },
{ 0x33, 0xff },
{ 0x34, 0x00 },
{ 0x35, 0x00 },
{ 0x36, 0x00 },
{ 0x37, 0x00 },
{ 0x38, 0x00 },
{ 0x39, 0x00 },
{ 0x3a, 0x00 },
{ 0x3b, 0x00 },
{ 0x3c, 0x00 },
{ 0x3d, 0x00 },
{ 0x3e, 0x00 },
{ 0x3f, 0x00 },
{ 0x40, 0x00 },
{ 0x41, 0x00 },
{ 0x42, 0x00 },
{ 0x43, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x13 },
{ 0x44, 0x7f },
{ 0x45, 0xff },
{ 0x46, 0xff },
{ 0x47, 0xff },
{ 0x48, 0x00 },
{ 0x49, 0x00 },
{ 0x4a, 0x00 },
{ 0x4b, 0x00 },
{ 0x4c, 0x00 },
{ 0x4d, 0x00 },
{ 0x4e, 0x00 },
{ 0x4f, 0x00 },
{ 0x50, 0x00 },
{ 0x51, 0x00 },
{ 0x52, 0x00 },
{ 0x53, 0x00 },
{ 0x54, 0x00 },
{ 0x55, 0x00 },
{ 0x56, 0x00 },
{ 0x57, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x13 },
{ 0x58, 0x4f },
{ 0x59, 0x9d },
{ 0x5a, 0xf9 },
{ 0x5b, 0x35 },
{ 0x5c, 0xb0 },
{ 0x5d, 0x62 },
{ 0x5e, 0x06 },
{ 0x5f, 0xcb },
{ 0x60, 0x4f },
{ 0x61, 0x9d },
{ 0x62, 0xf9 },
{ 0x63, 0x35 },
{ 0x64, 0x49 },
{ 0x65, 0xe6 },
{ 0x66, 0x9d },
{ 0x67, 0x16 },
{ 0x68, 0xd5 },
{ 0x69, 0x55 },
{ 0x6a, 0x55 },
{ 0x6b, 0x56 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x13 },
{ 0x6c, 0x4f },
{ 0x6d, 0x9d },
{ 0x6e, 0xf9 },
{ 0x6f, 0x35 },
{ 0x70, 0xb0 },
{ 0x71, 0x62 },
{ 0x72, 0x06 },
{ 0x73, 0xcb },
{ 0x74, 0x4f },
{ 0x75, 0x9d },
{ 0x76, 0xf9 },
{ 0x77, 0x35 },
{ 0x78, 0x49 },
{ 0x79, 0xe6 },
{ 0x7a, 0x9d },
{ 0x7b, 0x16 },
{ 0x7c, 0xd5 },
{ 0x7d, 0x55 },
{ 0x7e, 0x55 },
{ 0x7f, 0x56 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x14 },
{ 0x08, 0x7c },
{ 0x09, 0xb6 },
{ 0x0a, 0xa4 },
{ 0x0b, 0xbc },
{ 0x0c, 0x83 },
{ 0x0d, 0x49 },
{ 0x0e, 0x5b },
{ 0x0f, 0x44 },
{ 0x10, 0x7c },
{ 0x11, 0xb6 },
{ 0x12, 0xa4 },
{ 0x13, 0xbc },
{ 0x14, 0x7c },
{ 0x15, 0xb1 },
{ 0x16, 0x2c },
{ 0x17, 0x1e },
{ 0x18, 0x86 },
{ 0x19, 0x87 },
{ 0x1a, 0xc5 },
{ 0x1b, 0x49 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x14 },
{ 0x1c, 0x05 },
{ 0x1d, 0xb7 },
{ 0x1e, 0x5c },
{ 0x1f, 0x1f },
{ 0x20, 0x05 },
{ 0x21, 0xb7 },
{ 0x22, 0x5c },
{ 0x23, 0x1f },
{ 0x24, 0x05 },
{ 0x25, 0xb7 },
{ 0x26, 0x5c },
{ 0x27, 0x1f },
{ 0x28, 0x49 },
{ 0x29, 0xe6 },
{ 0x2a, 0x9d },
{ 0x2b, 0x16 },
{ 0x2c, 0xd5 },
{ 0x2d, 0x55 },
{ 0x2e, 0x55 },
{ 0x2f, 0x56 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x14 },
{ 0x30, 0x7c },
{ 0x31, 0xb6 },
{ 0x32, 0xa4 },
{ 0x33, 0xbc },
{ 0x34, 0x83 },
{ 0x35, 0x49 },
{ 0x36, 0x5b },
{ 0x37, 0x44 },
{ 0x38, 0x7c },
{ 0x39, 0xb6 },
{ 0x3a, 0xa4 },
{ 0x3b, 0xbc },
{ 0x3c, 0x7c },
{ 0x3d, 0xb1 },
{ 0x3e, 0x2c },
{ 0x3f, 0x1e },
{ 0x40, 0x86 },
{ 0x41, 0x87 },
{ 0x42, 0xc5 },
{ 0x43, 0x49 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x14 },
{ 0x44, 0x05 },
{ 0x45, 0xb7 },
{ 0x46, 0x5c },
{ 0x47, 0x1f },
{ 0x48, 0x05 },
{ 0x49, 0xb7 },
{ 0x4a, 0x5c },
{ 0x4b, 0x1f },
{ 0x4c, 0x05 },
{ 0x4d, 0xb7 },
{ 0x4e, 0x5c },
{ 0x4f, 0x1f },
{ 0x50, 0x49 },
{ 0x51, 0xe6 },
{ 0x52, 0x9d },
{ 0x53, 0x16 },
{ 0x54, 0xd5 },
{ 0x55, 0x55 },
{ 0x56, 0x55 },
{ 0x57, 0x56 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x14 },
{ 0x58, 0x7f },
{ 0x59, 0xff },
{ 0x5a, 0xff },
{ 0x5b, 0xff },
{ 0x5c, 0x00 },
{ 0x5d, 0x00 },
{ 0x5e, 0x00 },
{ 0x5f, 0x00 },
{ 0x60, 0x00 },
{ 0x61, 0x00 },
{ 0x62, 0x00 },
{ 0x63, 0x00 },
{ 0x64, 0x00 },
{ 0x65, 0x00 },
{ 0x66, 0x00 },
{ 0x67, 0x00 },
{ 0x68, 0x00 },
{ 0x69, 0x00 },
{ 0x6a, 0x00 },
{ 0x6b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x14 },
{ 0x6c, 0x7f },
{ 0x6d, 0xff },
{ 0x6e, 0xff },
{ 0x6f, 0xff },
{ 0x70, 0x00 },
{ 0x71, 0x00 },
{ 0x72, 0x00 },
{ 0x73, 0x00 },
{ 0x74, 0x00 },
{ 0x75, 0x00 },
{ 0x76, 0x00 },
{ 0x77, 0x00 },
{ 0x78, 0x00 },
{ 0x79, 0x00 },
{ 0x7a, 0x00 },
{ 0x7b, 0x00 },
{ 0x7c, 0x00 },
{ 0x7d, 0x00 },
{ 0x7e, 0x00 },
{ 0x7f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x15 },
{ 0x08, 0x7f },
{ 0x09, 0xff },
{ 0x0a, 0xff },
{ 0x0b, 0xff },
{ 0x0c, 0x00 },
{ 0x0d, 0x00 },
{ 0x0e, 0x00 },
{ 0x0f, 0x00 },
{ 0x10, 0x00 },
{ 0x11, 0x00 },
{ 0x12, 0x00 },
{ 0x13, 0x00 },
{ 0x14, 0x00 },
{ 0x15, 0x00 },
{ 0x16, 0x00 },
{ 0x17, 0x00 },
{ 0x18, 0x00 },
{ 0x19, 0x00 },
{ 0x1a, 0x00 },
{ 0x1b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x15 },
{ 0x1c, 0x7f },
{ 0x1d, 0xff },
{ 0x1e, 0xff },
{ 0x1f, 0xff },
{ 0x20, 0x00 },
{ 0x21, 0x00 },
{ 0x22, 0x00 },
{ 0x23, 0x00 },
{ 0x24, 0x00 },
{ 0x25, 0x00 },
{ 0x26, 0x00 },
{ 0x27, 0x00 },
{ 0x28, 0x00 },
{ 0x29, 0x00 },
{ 0x2a, 0x00 },
{ 0x2b, 0x00 },
{ 0x2c, 0x00 },
{ 0x2d, 0x00 },
{ 0x2e, 0x00 },
{ 0x2f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x15 },
{ 0x30, 0x7f },
{ 0x31, 0xff },
{ 0x32, 0xff },
{ 0x33, 0xff },
{ 0x34, 0x00 },
{ 0x35, 0x00 },
{ 0x36, 0x00 },
{ 0x37, 0x00 },
{ 0x38, 0x00 },
{ 0x39, 0x00 },
{ 0x3a, 0x00 },
{ 0x3b, 0x00 },
{ 0x3c, 0x00 },
{ 0x3d, 0x00 },
{ 0x3e, 0x00 },
{ 0x3f, 0x00 },
{ 0x40, 0x00 },
{ 0x41, 0x00 },
{ 0x42, 0x00 },
{ 0x43, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x15 },
{ 0x44, 0x7f },
{ 0x45, 0xff },
{ 0x46, 0xff },
{ 0x47, 0xff },
{ 0x48, 0x00 },
{ 0x49, 0x00 },
{ 0x4a, 0x00 },
{ 0x4b, 0x00 },
{ 0x4c, 0x00 },
{ 0x4d, 0x00 },
{ 0x4e, 0x00 },
{ 0x4f, 0x00 },
{ 0x50, 0x00 },
{ 0x51, 0x00 },
{ 0x52, 0x00 },
{ 0x53, 0x00 },
{ 0x54, 0x00 },
{ 0x55, 0x00 },
{ 0x56, 0x00 },
{ 0x57, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x15 },
{ 0x58, 0x7f },
{ 0x59, 0xff },
{ 0x5a, 0xff },
{ 0x5b, 0xff },
{ 0x5c, 0x80 },
{ 0x5d, 0x97 },
{ 0x5e, 0x78 },
{ 0x5f, 0xec },
{ 0x60, 0x7e },
{ 0x61, 0xd2 },
{ 0x62, 0x73 },
{ 0x63, 0xd9 },
{ 0x64, 0x7f },
{ 0x65, 0x94 },
{ 0x66, 0x6a },
{ 0x67, 0xcd },
{ 0x68, 0x80 },
{ 0x69, 0xd5 },
{ 0x6a, 0xc4 },
{ 0x6b, 0x3b },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x15 },
{ 0x6c, 0x7f },
{ 0x6d, 0xff },
{ 0x6e, 0xff },
{ 0x6f, 0xff },
{ 0x70, 0x81 },
{ 0x71, 0x4d },
{ 0x72, 0x3e },
{ 0x73, 0x51 },
{ 0x74, 0x7d },
{ 0x75, 0x6c },
{ 0x76, 0x3d },
{ 0x77, 0x0c },
{ 0x78, 0x7f },
{ 0x79, 0x12 },
{ 0x7a, 0x66 },
{ 0x7b, 0xad },
{ 0x7c, 0x81 },
{ 0x7d, 0xd4 },
{ 0x7e, 0x73 },
{ 0x7f, 0xe6 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x16 },
{ 0x08, 0x7f },
{ 0x09, 0xff },
{ 0x0a, 0xff },
{ 0x0b, 0xff },
{ 0x0c, 0xc5 },
{ 0x0d, 0xc8 },
{ 0x0e, 0x84 },
{ 0x0f, 0xcf },
{ 0x10, 0x24 },
{ 0x11, 0xa9 },
{ 0x12, 0x69 },
{ 0x13, 0x1a },
{ 0x14, 0x40 },
{ 0x15, 0xfd },
{ 0x16, 0x19 },
{ 0x17, 0xce },
{ 0x18, 0xc8 },
{ 0x19, 0x2f },
{ 0x1a, 0x2c },
{ 0x1b, 0x3e },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x16 },
{ 0x1c, 0x7f },
{ 0x1d, 0xff },
{ 0x1e, 0xff },
{ 0x1f, 0xff },
{ 0x20, 0x00 },
{ 0x21, 0x00 },
{ 0x22, 0x00 },
{ 0x23, 0x00 },
{ 0x24, 0x00 },
{ 0x25, 0x00 },
{ 0x26, 0x00 },
{ 0x27, 0x00 },
{ 0x28, 0x00 },
{ 0x29, 0x00 },
{ 0x2a, 0x00 },
{ 0x2b, 0x00 },
{ 0x2c, 0x00 },
{ 0x2d, 0x00 },
{ 0x2e, 0x00 },
{ 0x2f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x16 },
{ 0x30, 0x7f },
{ 0x31, 0xff },
{ 0x32, 0xff },
{ 0x33, 0xff },
{ 0x34, 0x00 },
{ 0x35, 0x00 },
{ 0x36, 0x00 },
{ 0x37, 0x00 },
{ 0x38, 0x00 },
{ 0x39, 0x00 },
{ 0x3a, 0x00 },
{ 0x3b, 0x00 },
{ 0x3c, 0x00 },
{ 0x3d, 0x00 },
{ 0x3e, 0x00 },
{ 0x3f, 0x00 },
{ 0x40, 0x00 },
{ 0x41, 0x00 },
{ 0x42, 0x00 },
{ 0x43, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x16 },
{ 0x44, 0x7f },
{ 0x45, 0xff },
{ 0x46, 0xff },
{ 0x47, 0xff },
{ 0x48, 0x00 },
{ 0x49, 0x00 },
{ 0x4a, 0x00 },
{ 0x4b, 0x00 },
{ 0x4c, 0x00 },
{ 0x4d, 0x00 },
{ 0x4e, 0x00 },
{ 0x4f, 0x00 },
{ 0x50, 0x00 },
{ 0x51, 0x00 },
{ 0x52, 0x00 },
{ 0x53, 0x00 },
{ 0x54, 0x00 },
{ 0x55, 0x00 },
{ 0x56, 0x00 },
{ 0x57, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x16 },
{ 0x58, 0x7f },
{ 0x59, 0xff },
{ 0x5a, 0xff },
{ 0x5b, 0xff },
{ 0x5c, 0x00 },
{ 0x5d, 0x00 },
{ 0x5e, 0x00 },
{ 0x5f, 0x00 },
{ 0x60, 0x00 },
{ 0x61, 0x00 },
{ 0x62, 0x00 },
{ 0x63, 0x00 },
{ 0x64, 0x00 },
{ 0x65, 0x00 },
{ 0x66, 0x00 },
{ 0x67, 0x00 },
{ 0x68, 0x00 },
{ 0x69, 0x00 },
{ 0x6a, 0x00 },
{ 0x6b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x16 },
{ 0x6c, 0x7f },
{ 0x6d, 0xff },
{ 0x6e, 0xff },
{ 0x6f, 0xff },
{ 0x70, 0x00 },
{ 0x71, 0x00 },
{ 0x72, 0x00 },
{ 0x73, 0x00 },
{ 0x74, 0x00 },
{ 0x75, 0x00 },
{ 0x76, 0x00 },
{ 0x77, 0x00 },
{ 0x78, 0x00 },
{ 0x79, 0x00 },
{ 0x7a, 0x00 },
{ 0x7b, 0x00 },
{ 0x7c, 0x00 },
{ 0x7d, 0x00 },
{ 0x7e, 0x00 },
{ 0x7f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x17 },
{ 0x08, 0x7f },
{ 0x09, 0xff },
{ 0x0a, 0xff },
{ 0x0b, 0xff },
{ 0x0c, 0x00 },
{ 0x0d, 0x00 },
{ 0x0e, 0x00 },
{ 0x0f, 0x00 },
{ 0x10, 0x00 },
{ 0x11, 0x00 },
{ 0x12, 0x00 },
{ 0x13, 0x00 },
{ 0x14, 0x00 },
{ 0x15, 0x00 },
{ 0x16, 0x00 },
{ 0x17, 0x00 },
{ 0x18, 0x00 },
{ 0x19, 0x00 },
{ 0x1a, 0x00 },
{ 0x1b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x17 },
{ 0x1c, 0x7f },
{ 0x1d, 0xff },
{ 0x1e, 0xff },
{ 0x1f, 0xff },
{ 0x20, 0x00 },
{ 0x21, 0x00 },
{ 0x22, 0x00 },
{ 0x23, 0x00 },
{ 0x24, 0x00 },
{ 0x25, 0x00 },
{ 0x26, 0x00 },
{ 0x27, 0x00 },
{ 0x28, 0x00 },
{ 0x29, 0x00 },
{ 0x2a, 0x00 },
{ 0x2b, 0x00 },
{ 0x2c, 0x00 },
{ 0x2d, 0x00 },
{ 0x2e, 0x00 },
{ 0x2f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x17 },
{ 0x30, 0x7f },
{ 0x31, 0xff },
{ 0x32, 0xff },
{ 0x33, 0xff },
{ 0x34, 0x00 },
{ 0x35, 0x00 },
{ 0x36, 0x00 },
{ 0x37, 0x00 },
{ 0x38, 0x00 },
{ 0x39, 0x00 },
{ 0x3a, 0x00 },
{ 0x3b, 0x00 },
{ 0x3c, 0x00 },
{ 0x3d, 0x00 },
{ 0x3e, 0x00 },
{ 0x3f, 0x00 },
{ 0x40, 0x00 },
{ 0x41, 0x00 },
{ 0x42, 0x00 },
{ 0x43, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x17 },
{ 0x44, 0x7f },
{ 0x45, 0xff },
{ 0x46, 0xff },
{ 0x47, 0xff },
{ 0x48, 0x00 },
{ 0x49, 0x00 },
{ 0x4a, 0x00 },
{ 0x4b, 0x00 },
{ 0x4c, 0x00 },
{ 0x4d, 0x00 },
{ 0x4e, 0x00 },
{ 0x4f, 0x00 },
{ 0x50, 0x00 },
{ 0x51, 0x00 },
{ 0x52, 0x00 },
{ 0x53, 0x00 },
{ 0x54, 0x00 },
{ 0x55, 0x00 },
{ 0x56, 0x00 },
{ 0x57, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x17 },
{ 0x58, 0x7f },
{ 0x59, 0xff },
{ 0x5a, 0xff },
{ 0x5b, 0xff },
{ 0x5c, 0x00 },
{ 0x5d, 0x00 },
{ 0x5e, 0x00 },
{ 0x5f, 0x00 },
{ 0x60, 0x00 },
{ 0x61, 0x00 },
{ 0x62, 0x00 },
{ 0x63, 0x00 },
{ 0x64, 0x00 },
{ 0x65, 0x00 },
{ 0x66, 0x00 },
{ 0x67, 0x00 },
{ 0x68, 0x00 },
{ 0x69, 0x00 },
{ 0x6a, 0x00 },
{ 0x6b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x17 },
{ 0x6c, 0x7f },
{ 0x6d, 0xff },
{ 0x6e, 0xff },
{ 0x6f, 0xff },
{ 0x70, 0x00 },
{ 0x71, 0x00 },
{ 0x72, 0x00 },
{ 0x73, 0x00 },
{ 0x74, 0x00 },
{ 0x75, 0x00 },
{ 0x76, 0x00 },
{ 0x77, 0x00 },
{ 0x78, 0x00 },
{ 0x79, 0x00 },
{ 0x7a, 0x00 },
{ 0x7b, 0x00 },
{ 0x7c, 0x00 },
{ 0x7d, 0x00 },
{ 0x7e, 0x00 },
{ 0x7f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x18 },
{ 0x08, 0x08 },
{ 0x09, 0xf8 },
{ 0x0a, 0x0e },
{ 0x0b, 0x93 },
{ 0x0c, 0x00 },
{ 0x0d, 0x00 },
{ 0x0e, 0x00 },
{ 0x0f, 0x00 },
{ 0x10, 0x00 },
{ 0x11, 0x00 },
{ 0x12, 0x00 },
{ 0x13, 0x00 },
{ 0x14, 0x00 },
{ 0x15, 0x00 },
{ 0x16, 0x00 },
{ 0x17, 0x00 },
{ 0x18, 0x00 },
{ 0x19, 0x00 },
{ 0x1a, 0x00 },
{ 0x1b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x18 },
{ 0x1c, 0x7f },
{ 0x1d, 0xff },
{ 0x1e, 0xff },
{ 0x1f, 0xff },
{ 0x20, 0x00 },
{ 0x21, 0x00 },
{ 0x22, 0x00 },
{ 0x23, 0x00 },
{ 0x24, 0x00 },
{ 0x25, 0x00 },
{ 0x26, 0x00 },
{ 0x27, 0x00 },
{ 0x28, 0x00 },
{ 0x29, 0x00 },
{ 0x2a, 0x00 },
{ 0x2b, 0x00 },
{ 0x2c, 0x00 },
{ 0x2d, 0x00 },
{ 0x2e, 0x00 },
{ 0x2f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x18 },
{ 0x30, 0x7f },
{ 0x31, 0xff },
{ 0x32, 0xff },
{ 0x33, 0xff },
{ 0x34, 0x00 },
{ 0x35, 0x00 },
{ 0x36, 0x00 },
{ 0x37, 0x00 },
{ 0x38, 0x00 },
{ 0x39, 0x00 },
{ 0x3a, 0x00 },
{ 0x3b, 0x00 },
{ 0x3c, 0x00 },
{ 0x3d, 0x00 },
{ 0x3e, 0x00 },
{ 0x3f, 0x00 },
{ 0x40, 0x00 },
{ 0x41, 0x00 },
{ 0x42, 0x00 },
{ 0x43, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x18 },
{ 0x44, 0x7f },
{ 0x45, 0xff },
{ 0x46, 0xff },
{ 0x47, 0xff },
{ 0x48, 0x00 },
{ 0x49, 0x00 },
{ 0x4a, 0x00 },
{ 0x4b, 0x00 },
{ 0x4c, 0x00 },
{ 0x4d, 0x00 },
{ 0x4e, 0x00 },
{ 0x4f, 0x00 },
{ 0x50, 0x00 },
{ 0x51, 0x00 },
{ 0x52, 0x00 },
{ 0x53, 0x00 },
{ 0x54, 0x00 },
{ 0x55, 0x00 },
{ 0x56, 0x00 },
{ 0x57, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x18 },
{ 0x58, 0x7f },
{ 0x59, 0xff },
{ 0x5a, 0xff },
{ 0x5b, 0xff },
{ 0x5c, 0x00 },
{ 0x5d, 0x00 },
{ 0x5e, 0x00 },
{ 0x5f, 0x00 },
{ 0x60, 0x00 },
{ 0x61, 0x00 },
{ 0x62, 0x00 },
{ 0x63, 0x00 },
{ 0x64, 0x00 },
{ 0x65, 0x00 },
{ 0x66, 0x00 },
{ 0x67, 0x00 },
{ 0x68, 0x00 },
{ 0x69, 0x00 },
{ 0x6a, 0x00 },
{ 0x6b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x18 },
{ 0x6c, 0x7f },
{ 0x6d, 0xff },
{ 0x6e, 0xff },
{ 0x6f, 0xff },
{ 0x70, 0x00 },
{ 0x71, 0x00 },
{ 0x72, 0x00 },
{ 0x73, 0x00 },
{ 0x74, 0x00 },
{ 0x75, 0x00 },
{ 0x76, 0x00 },
{ 0x77, 0x00 },
{ 0x78, 0x00 },
{ 0x79, 0x00 },
{ 0x7a, 0x00 },
{ 0x7b, 0x00 },
{ 0x7c, 0x00 },
{ 0x7d, 0x00 },
{ 0x7e, 0x00 },
{ 0x7f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x19 },
{ 0x08, 0x7f },
{ 0x09, 0xff },
{ 0x0a, 0xff },
{ 0x0b, 0xff },
{ 0x0c, 0x00 },
{ 0x0d, 0x00 },
{ 0x0e, 0x00 },
{ 0x0f, 0x00 },
{ 0x10, 0x00 },
{ 0x11, 0x00 },
{ 0x12, 0x00 },
{ 0x13, 0x00 },
{ 0x14, 0x00 },
{ 0x15, 0x00 },
{ 0x16, 0x00 },
{ 0x17, 0x00 },
{ 0x18, 0x00 },
{ 0x19, 0x00 },
{ 0x1a, 0x00 },
{ 0x1b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x19 },
{ 0x1c, 0x7f },
{ 0x1d, 0xff },
{ 0x1e, 0xff },
{ 0x1f, 0xff },
{ 0x20, 0x00 },
{ 0x21, 0x00 },
{ 0x22, 0x00 },
{ 0x23, 0x00 },
{ 0x24, 0x00 },
{ 0x25, 0x00 },
{ 0x26, 0x00 },
{ 0x27, 0x00 },
{ 0x28, 0x00 },
{ 0x29, 0x00 },
{ 0x2a, 0x00 },
{ 0x2b, 0x00 },
{ 0x2c, 0x00 },
{ 0x2d, 0x00 },
{ 0x2e, 0x00 },
{ 0x2f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x19 },
{ 0x30, 0x7f },
{ 0x31, 0xff },
{ 0x32, 0xff },
{ 0x33, 0xff },
{ 0x34, 0x00 },
{ 0x35, 0x00 },
{ 0x36, 0x00 },
{ 0x37, 0x00 },
{ 0x38, 0x00 },
{ 0x39, 0x00 },
{ 0x3a, 0x00 },
{ 0x3b, 0x00 },
{ 0x3c, 0x00 },
{ 0x3d, 0x00 },
{ 0x3e, 0x00 },
{ 0x3f, 0x00 },
{ 0x40, 0x00 },
{ 0x41, 0x00 },
{ 0x42, 0x00 },
{ 0x43, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x19 },
{ 0x44, 0x7f },
{ 0x45, 0xff },
{ 0x46, 0xff },
{ 0x47, 0xff },
{ 0x48, 0x00 },
{ 0x49, 0x00 },
{ 0x4a, 0x00 },
{ 0x4b, 0x00 },
{ 0x4c, 0x00 },
{ 0x4d, 0x00 },
{ 0x4e, 0x00 },
{ 0x4f, 0x00 },
{ 0x50, 0x00 },
{ 0x51, 0x00 },
{ 0x52, 0x00 },
{ 0x53, 0x00 },
{ 0x54, 0x00 },
{ 0x55, 0x00 },
{ 0x56, 0x00 },
{ 0x57, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x19 },
{ 0x58, 0x7f },
{ 0x59, 0xff },
{ 0x5a, 0xff },
{ 0x5b, 0xff },
{ 0x5c, 0x00 },
{ 0x5d, 0x00 },
{ 0x5e, 0x00 },
{ 0x5f, 0x00 },
{ 0x60, 0x00 },
{ 0x61, 0x00 },
{ 0x62, 0x00 },
{ 0x63, 0x00 },
{ 0x64, 0x00 },
{ 0x65, 0x00 },
{ 0x66, 0x00 },
{ 0x67, 0x00 },
{ 0x68, 0x00 },
{ 0x69, 0x00 },
{ 0x6a, 0x00 },
{ 0x6b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x19 },
{ 0x6c, 0x7f },
{ 0x6d, 0xff },
{ 0x6e, 0xff },
{ 0x6f, 0xff },
{ 0x70, 0x00 },
{ 0x71, 0x00 },
{ 0x72, 0x00 },
{ 0x73, 0x00 },
{ 0x74, 0x00 },
{ 0x75, 0x00 },
{ 0x76, 0x00 },
{ 0x77, 0x00 },
{ 0x78, 0x00 },
{ 0x79, 0x00 },
{ 0x7a, 0x00 },
{ 0x7b, 0x00 },
{ 0x7c, 0x00 },
{ 0x7d, 0x00 },
{ 0x7e, 0x00 },
{ 0x7f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1a },
{ 0x08, 0x7f },
{ 0x09, 0xff },
{ 0x0a, 0xff },
{ 0x0b, 0xff },
{ 0x0c, 0x00 },
{ 0x0d, 0x00 },
{ 0x0e, 0x00 },
{ 0x0f, 0x00 },
{ 0x10, 0x00 },
{ 0x11, 0x00 },
{ 0x12, 0x00 },
{ 0x13, 0x00 },
{ 0x14, 0x00 },
{ 0x15, 0x00 },
{ 0x16, 0x00 },
{ 0x17, 0x00 },
{ 0x18, 0x00 },
{ 0x19, 0x00 },
{ 0x1a, 0x00 },
{ 0x1b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1a },
{ 0x1c, 0x7f },
{ 0x1d, 0xff },
{ 0x1e, 0xff },
{ 0x1f, 0xff },
{ 0x20, 0x00 },
{ 0x21, 0x00 },
{ 0x22, 0x00 },
{ 0x23, 0x00 },
{ 0x24, 0x00 },
{ 0x25, 0x00 },
{ 0x26, 0x00 },
{ 0x27, 0x00 },
{ 0x28, 0x00 },
{ 0x29, 0x00 },
{ 0x2a, 0x00 },
{ 0x2b, 0x00 },
{ 0x2c, 0x00 },
{ 0x2d, 0x00 },
{ 0x2e, 0x00 },
{ 0x2f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1a },
{ 0x30, 0x7f },
{ 0x31, 0xff },
{ 0x32, 0xff },
{ 0x33, 0xff },
{ 0x34, 0x00 },
{ 0x35, 0x00 },
{ 0x36, 0x00 },
{ 0x37, 0x00 },
{ 0x38, 0x00 },
{ 0x39, 0x00 },
{ 0x3a, 0x00 },
{ 0x3b, 0x00 },
{ 0x3c, 0x00 },
{ 0x3d, 0x00 },
{ 0x3e, 0x00 },
{ 0x3f, 0x00 },
{ 0x40, 0x00 },
{ 0x41, 0x00 },
{ 0x42, 0x00 },
{ 0x43, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1a },
{ 0x44, 0x08 },
{ 0x45, 0x00 },
{ 0x46, 0x00 },
{ 0x47, 0x00 },
{ 0x48, 0x00 },
{ 0x49, 0x00 },
{ 0x4a, 0x00 },
{ 0x4b, 0x00 },
{ 0x4c, 0x00 },
{ 0x4d, 0x00 },
{ 0x4e, 0x00 },
{ 0x4f, 0x00 },
{ 0x50, 0x00 },
{ 0x51, 0x00 },
{ 0x52, 0x00 },
{ 0x53, 0x00 },
{ 0x54, 0x00 },
{ 0x55, 0x00 },
{ 0x56, 0x00 },
{ 0x57, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1a },
{ 0x58, 0x7f },
{ 0x59, 0xff },
{ 0x5a, 0xff },
{ 0x5b, 0xff },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1a },
{ 0x60, 0x00 },
{ 0x61, 0x00 },
{ 0x62, 0x00 },
{ 0x63, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1a },
{ 0x64, 0x00 },
{ 0x65, 0x00 },
{ 0x66, 0x00 },
{ 0x67, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1a },
{ 0x68, 0x00 },
{ 0x69, 0x00 },
{ 0x6a, 0x00 },
{ 0x6b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1a },
{ 0x6c, 0x00 },
{ 0x6d, 0x06 },
{ 0x6e, 0xd3 },
{ 0x6f, 0x72 },
{ 0x70, 0x00 },
{ 0x71, 0x02 },
{ 0x72, 0xbb },
{ 0x73, 0x06 },
{ 0x74, 0x00 },
{ 0x75, 0x03 },
{ 0x76, 0x69 },
{ 0x77, 0xc5 },
{ 0x78, 0x00 },
{ 0x79, 0x00 },
{ 0x7a, 0x00 },
{ 0x7b, 0x00 },
{ 0x7c, 0x00 },
{ 0x7d, 0x00 },
{ 0x7e, 0x00 },
{ 0x7f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1b },
{ 0x08, 0x00 },
{ 0x09, 0x00 },
{ 0x0a, 0x00 },
{ 0x0b, 0x00 },
{ 0x0c, 0xf9 },
{ 0x0d, 0xda },
{ 0x0e, 0xbc },
{ 0x0f, 0x21 },
{ 0x10, 0xfc },
{ 0x11, 0x58 },
{ 0x12, 0x8b },
{ 0x13, 0x89 },
{ 0x14, 0x00 },
{ 0x15, 0x00 },
{ 0x16, 0x00 },
{ 0x17, 0x00 },
{ 0x18, 0x00 },
{ 0x19, 0x00 },
{ 0x1a, 0x00 },
{ 0x1b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1b },
{ 0x1c, 0x00 },
{ 0x1d, 0x06 },
{ 0x1e, 0xd3 },
{ 0x1f, 0x72 },
{ 0x20, 0x00 },
{ 0x21, 0x02 },
{ 0x22, 0xbb },
{ 0x23, 0x06 },
{ 0x24, 0x00 },
{ 0x25, 0x03 },
{ 0x26, 0x69 },
{ 0x27, 0xc5 },
{ 0x28, 0x00 },
{ 0x29, 0x00 },
{ 0x2a, 0x00 },
{ 0x2b, 0x00 },
{ 0x2c, 0x00 },
{ 0x2d, 0x00 },
{ 0x2e, 0x00 },
{ 0x2f, 0x00 },
{ 0x30, 0x00 },
{ 0x31, 0x00 },
{ 0x32, 0x00 },
{ 0x33, 0x00 },
{ 0x34, 0xf9 },
{ 0x35, 0xda },
{ 0x36, 0xbc },
{ 0x37, 0x21 },
{ 0x38, 0xfc },
{ 0x39, 0x58 },
{ 0x3a, 0x8b },
{ 0x3b, 0x89 },
{ 0x3c, 0x00 },
{ 0x3d, 0x00 },
{ 0x3e, 0x00 },
{ 0x3f, 0x00 },
{ 0x40, 0x00 },
{ 0x41, 0x00 },
{ 0x42, 0x00 },
{ 0x43, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1b },
{ 0x44, 0x00 },
{ 0x45, 0x06 },
{ 0x46, 0xd3 },
{ 0x47, 0x72 },
{ 0x48, 0x00 },
{ 0x49, 0x02 },
{ 0x4a, 0xbb },
{ 0x4b, 0x06 },
{ 0x4c, 0x00 },
{ 0x4d, 0x03 },
{ 0x4e, 0x69 },
{ 0x4f, 0xc5 },
{ 0x50, 0x00 },
{ 0x51, 0x00 },
{ 0x52, 0x00 },
{ 0x53, 0x00 },
{ 0x54, 0x00 },
{ 0x55, 0x00 },
{ 0x56, 0x00 },
{ 0x57, 0x00 },
{ 0x58, 0x00 },
{ 0x59, 0x00 },
{ 0x5a, 0x00 },
{ 0x5b, 0x00 },
{ 0x5c, 0xf9 },
{ 0x5d, 0xda },
{ 0x5e, 0xbc },
{ 0x5f, 0x21 },
{ 0x60, 0xfc },
{ 0x61, 0x58 },
{ 0x62, 0x8b },
{ 0x63, 0x89 },
{ 0x64, 0x00 },
{ 0x65, 0x00 },
{ 0x66, 0x00 },
{ 0x67, 0x00 },
{ 0x68, 0x00 },
{ 0x69, 0x00 },
{ 0x6a, 0x00 },
{ 0x6b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1b },
{ 0x6c, 0x00 },
{ 0x6d, 0x06 },
{ 0x6e, 0xd3 },
{ 0x6f, 0x72 },
{ 0x70, 0x00 },
{ 0x71, 0x02 },
{ 0x72, 0xbb },
{ 0x73, 0x06 },
{ 0x74, 0x00 },
{ 0x75, 0x03 },
{ 0x76, 0x69 },
{ 0x77, 0xc5 },
{ 0x78, 0x00 },
{ 0x79, 0x00 },
{ 0x7a, 0x00 },
{ 0x7b, 0x00 },
{ 0x7c, 0x00 },
{ 0x7d, 0x00 },
{ 0x7e, 0x00 },
{ 0x7f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1c },
{ 0x08, 0x00 },
{ 0x09, 0x00 },
{ 0x0a, 0x00 },
{ 0x0b, 0x00 },
{ 0x0c, 0xf9 },
{ 0x0d, 0xda },
{ 0x0e, 0xbc },
{ 0x0f, 0x21 },
{ 0x10, 0xfc },
{ 0x11, 0x58 },
{ 0x12, 0x8b },
{ 0x13, 0x89 },
{ 0x14, 0x00 },
{ 0x15, 0x00 },
{ 0x16, 0x00 },
{ 0x17, 0x00 },
{ 0x18, 0x00 },
{ 0x19, 0x00 },
{ 0x1a, 0x00 },
{ 0x1b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1c },
{ 0x1c, 0x00 },
{ 0x1d, 0x06 },
{ 0x1e, 0xd3 },
{ 0x1f, 0x72 },
{ 0x20, 0x00 },
{ 0x21, 0x02 },
{ 0x22, 0xbb },
{ 0x23, 0x06 },
{ 0x24, 0x00 },
{ 0x25, 0x03 },
{ 0x26, 0x69 },
{ 0x27, 0xc5 },
{ 0x28, 0x00 },
{ 0x29, 0x00 },
{ 0x2a, 0x00 },
{ 0x2b, 0x00 },
{ 0x2c, 0x00 },
{ 0x2d, 0x00 },
{ 0x2e, 0x00 },
{ 0x2f, 0x00 },
{ 0x30, 0x00 },
{ 0x31, 0x00 },
{ 0x32, 0x00 },
{ 0x33, 0x00 },
{ 0x34, 0xf9 },
{ 0x35, 0xda },
{ 0x36, 0xbc },
{ 0x37, 0x21 },
{ 0x38, 0xfc },
{ 0x39, 0x58 },
{ 0x3a, 0x8b },
{ 0x3b, 0x89 },
{ 0x3c, 0x00 },
{ 0x3d, 0x00 },
{ 0x3e, 0x00 },
{ 0x3f, 0x00 },
{ 0x40, 0x00 },
{ 0x41, 0x00 },
{ 0x42, 0x00 },
{ 0x43, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1c },
{ 0x44, 0x00 },
{ 0x45, 0x06 },
{ 0x46, 0xd3 },
{ 0x47, 0x72 },
{ 0x48, 0x00 },
{ 0x49, 0x02 },
{ 0x4a, 0xbb },
{ 0x4b, 0x06 },
{ 0x4c, 0x00 },
{ 0x4d, 0x03 },
{ 0x4e, 0x69 },
{ 0x4f, 0xc5 },
{ 0x50, 0x00 },
{ 0x51, 0x00 },
{ 0x52, 0x00 },
{ 0x53, 0x00 },
{ 0x54, 0x00 },
{ 0x55, 0x00 },
{ 0x56, 0x00 },
{ 0x57, 0x00 },
{ 0x58, 0x00 },
{ 0x59, 0x00 },
{ 0x5a, 0x00 },
{ 0x5b, 0x00 },
{ 0x5c, 0xf9 },
{ 0x5d, 0xda },
{ 0x5e, 0xbc },
{ 0x5f, 0x21 },
{ 0x60, 0xfc },
{ 0x61, 0x58 },
{ 0x62, 0x8b },
{ 0x63, 0x89 },
{ 0x64, 0x00 },
{ 0x65, 0x00 },
{ 0x66, 0x00 },
{ 0x67, 0x00 },
{ 0x68, 0x00 },
{ 0x69, 0x00 },
{ 0x6a, 0x00 },
{ 0x6b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x1c, 0x00 },
{ 0x1d, 0x06 },
{ 0x1e, 0xd3 },
{ 0x1f, 0x72 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x20, 0x1c },
{ 0x21, 0x1b },
{ 0x22, 0xf0 },
{ 0x23, 0x41 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x24, 0x04 },
{ 0x25, 0x0c },
{ 0x26, 0x37 },
{ 0x27, 0x14 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x2c, 0x00 },
{ 0x2d, 0x80 },
{ 0x2e, 0x00 },
{ 0x2f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x30, 0x00 },
{ 0x31, 0x80 },
{ 0x32, 0x00 },
{ 0x33, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x34, 0x40 },
{ 0x35, 0x00 },
{ 0x36, 0x00 },
{ 0x37, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x38, 0x40 },
{ 0x39, 0x00 },
{ 0x3a, 0x00 },
{ 0x3b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x3c, 0x40 },
{ 0x3d, 0x00 },
{ 0x3e, 0x00 },
{ 0x3f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x40, 0x00 },
{ 0x41, 0x80 },
{ 0x42, 0x00 },
{ 0x43, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x44, 0x00 },
{ 0x45, 0x00 },
{ 0x46, 0x00 },
{ 0x47, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x48, 0x00 },
{ 0x49, 0x00 },
{ 0x4a, 0x00 },
{ 0x4b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x4c, 0x00 },
{ 0x4d, 0x80 },
{ 0x4e, 0x00 },
{ 0x4f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x50, 0x00 },
{ 0x51, 0x00 },
{ 0x52, 0x00 },
{ 0x53, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x54, 0x00 },
{ 0x55, 0x00 },
{ 0x56, 0x00 },
{ 0x57, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x58, 0x00 },
{ 0x59, 0x00 },
{ 0x5a, 0x00 },
{ 0x5b, 0x01 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x5c, 0x00 },
{ 0x5d, 0x80 },
{ 0x5e, 0x00 },
{ 0x5f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x60, 0x00 },
{ 0x61, 0x00 },
{ 0x62, 0x00 },
{ 0x63, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x64, 0x00 },
{ 0x65, 0x00 },
{ 0x66, 0x00 },
{ 0x67, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1d },
{ 0x68, 0x00 },
{ 0x69, 0x00 },
{ 0x6a, 0x00 },
{ 0x6b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x14, 0x00 },
{ 0x15, 0x80 },
{ 0x16, 0x00 },
{ 0x17, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x18, 0x00 },
{ 0x19, 0x00 },
{ 0x1a, 0x00 },
{ 0x1b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x1c, 0x00 },
{ 0x1d, 0x00 },
{ 0x1e, 0x00 },
{ 0x1f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x20, 0x00 },
{ 0x21, 0x00 },
{ 0x22, 0x00 },
{ 0x23, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x24, 0x00 },
{ 0x25, 0x00 },
{ 0x26, 0x00 },
{ 0x27, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x28, 0x00 },
{ 0x29, 0x80 },
{ 0x2a, 0x00 },
{ 0x2b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x2c, 0x00 },
{ 0x2d, 0x80 },
{ 0x2e, 0x00 },
{ 0x2f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x30, 0x00 },
{ 0x31, 0x00 },
{ 0x32, 0x00 },
{ 0x33, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x34, 0x00 },
{ 0x35, 0x00 },
{ 0x36, 0x00 },
{ 0x37, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x38, 0x00 },
{ 0x39, 0x00 },
{ 0x3a, 0x00 },
{ 0x3b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x3c, 0x00 },
{ 0x3d, 0x00 },
{ 0x3e, 0x00 },
{ 0x3f, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x40, 0x00 },
{ 0x41, 0x80 },
{ 0x42, 0x00 },
{ 0x43, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x44, 0x00 },
{ 0x45, 0x80 },
{ 0x46, 0x00 },
{ 0x47, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x48, 0x00 },
{ 0x49, 0x80 },
{ 0x4a, 0x00 },
{ 0x4b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x50, 0x40 },
{ 0x51, 0x00 },
{ 0x52, 0x00 },
{ 0x53, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x54, 0x04 },
{ 0x55, 0x00 },
{ 0x56, 0x00 },
{ 0x57, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x58, 0x04 },
{ 0x59, 0x00 },
{ 0x5a, 0x00 },
{ 0x5b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x6c, 0x00 },
{ 0x6d, 0xce },
{ 0x6e, 0xc0 },
{ 0x6f, 0x8a },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x70, 0x0a },
{ 0x71, 0x0a },
{ 0x72, 0xae },
{ 0x73, 0xd2 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x74, 0x00 },
{ 0x75, 0x03 },
{ 0x76, 0x69 },
{ 0x77, 0xd0 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1e },
{ 0x78, 0x40 },
{ 0x79, 0x00 },
{ 0x7a, 0x00 },
{ 0x7b, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1f },
{ 0x08, 0x75 },
{ 0x09, 0xf5 },
{ 0x0a, 0x51 },
{ 0x0b, 0x2e },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1f },
{ 0x0c, 0x00 },
{ 0x0d, 0x00 },
{ 0x0e, 0x57 },
{ 0x0f, 0x62 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1f },
{ 0x14, 0x00 },
{ 0x15, 0xce },
{ 0x16, 0xc0 },
{ 0x17, 0x8a },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1f },
{ 0x18, 0x0a },
{ 0x19, 0x0a },
{ 0x1a, 0xae },
{ 0x1b, 0xd2 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1f },
{ 0x1c, 0x00 },
{ 0x1d, 0x03 },
{ 0x1e, 0x69 },
{ 0x1f, 0xd0 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1f },
{ 0x20, 0x40 },
{ 0x21, 0x00 },
{ 0x22, 0x00 },
{ 0x23, 0x00 },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1f },
{ 0x28, 0x75 },
{ 0x29, 0xf5 },
{ 0x2a, 0x51 },
{ 0x2b, 0x2e },
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x1f },
{ 0x2c, 0x00 },
{ 0x2d, 0x00 },
{ 0x2e, 0x57 },
{ 0x2f, 0x62 },
//swap command
{ 0x00, 0x00 },
{ 0x7f, 0x8c },
{ 0x00, 0x23 },
{ 0x14, 0x00 },
{ 0x15, 0x00 },
{ 0x16, 0x00 },
{ 0x17, 0x01 },
//register tuning
{ 0x00, 0x00 },
{ 0x7f, 0x00 },
{ 0x00, 0x00 },
{ 0x07, 0x00 },
{ 0x08, 0x20 },
{ 0x55, 0x07 },
{ 0x00, 0x00 },
{ 0x7f, 0x00 },
{ 0x00, 0x00 },
{ 0x3d, 0x30 },
{ 0x3e, 0x30 },
{ 0x00, 0x00 },
{ 0x7f, 0x00 },
{ 0x00, 0x01 },
{ 0x02, 0x00 },
//Unmute the device
{ 0x00, 0x00 },
{ 0x7f, 0x00 },
{ 0x03, 0x00 },
{ 0x2a, 0x11 },
