Part Number: TAS5760LD
Hi Team,
Please help me answer the follow question, thank you so much.
Jitter is occurred in the “I2S_SCLK”. It was found that noise is generated in the audio signal due to this jitter. Is there a setting that can reduce the effect of jitter on the IC side?
Connect “I2S_SCLK” of Bluetooth module and “MCLK” of TAS5760LDAP via 22Ω resistor.
Connect “I2S_SCLK” of Bluetooth module and “SCLK” of TAS5760LDAP via 22Ω resistor.
Connect “I2S_SDOUT” of Bluetooth module and “SDIN” of TAS5760LDAP via 22Ω resistor.
Currently, we are in the final stage of prototyping and can not add the circuit of Clock jitter cleaner. Is there a setting that can improve the noise just by changing the setting of I2C?
Tom.Liu
