TPA3110D2: TPA3110D2 PLIMIT Function
Part Number: TPA3110D2
Hi.
I designed the AUDIO AMP board using the TPA3110D2.
I'm trying to adjust the output gain using a variable resistor between GVDD and PLIMIT, but it doesn't work.
At this time, Gain0 and Gain1 applied Low.
When I change the PLIMIT voltage, the output volume does not change.
Does the PLIMIT function not work in the Mono Input mode?
Test Condition --> PVCC : 12V, Input : Pin 12(RINP), PBTL : High, Gain0/Gain1 : Low, Mono Input
Thanks.
