TAS5411-Q1: frequency dependent overcurrent shutdown
Part Number: TAS5411-Q1
we are working on a project with this amplifier to synthesize audio. We need high volume so when we operate in high gain, below 200 Hz and above 600 Hz, the amplifier goes in to overcurrent mode.
I was suspicious with the Slew Rate but, could not find the parameter in the datasheet. However, it can be something else. Would you have any suggestion ?
Thank you in advance.
