CC8520 Problem.
Other Parts Discussed in Thread: TLV320AIC3104, CC8520
I have CC8520 and TLV320AIC3104 audio codec. I made 2 layer PCB for CC8520 and 2 layer PCB for TLV320AIC3104 as datasheet and referance design show. When i try to connect two CC8520 with codec, they find network and i can have audio. But after a few minutes or if i touch the ground of the PCB with a metal, i lose audio; but network indicator led stay on ( it means there is a network connection ). If i hold PCB ground with my hand and touch PCB with a metal, it continues working. Exposed pad of CC8520 is well soldered. What can be the problem?
  • Hi Saci,
    This seems more like a design and grounding issue. Can you please upload your design files/schematics for the 2 boards so that it can help to find the error.
    -The Air team @ Anaren.
    Please check out our Air Modules at http://www.anaren.com/content/File/AIR/AIRoverview.cfm
    Anaren is a third party Developer Network Member for Low Power RF and MCUs.
