TAS5727: Maximum total rated power
Part Number: TAS5727
Dear experts,
My customer is using TAS5727, and they wonder what's the maximum output power? And what's the test condition? They are confused by the datasheet. Thanks.
  • Hi Minqi,
    Normally we talk about maximum output power under specific conditions, as it is determined by many factors (output configuration, THD level, power supply and load resistance). That's why you see a lot of different specs in the datasheet.
    70W here means the maximum allowed output power under all possible circuit conditions (for example, PVDD=25V, RL=8ohm). We recommend customer to select the spec which is under similar conditions with their application. Thanks
    Hector Zhang
