Dear TI :
Can you help check the schematic and components for TAS2557 design ?
Dear Luis :
Thanks for your support
Please refer the schematic and data sheet of bead and inductance.
Because the design is related from our old project.
There are two PCB board including main board and speaker board and use FPC to connect.
The Vsense cannot directly connect to speaker pad.3808.TAS2557 schematic.pdf47nH_LQW18AN47NJ00.PDFBead_MPZ1608S221A.PDF
Hi, Luis
We are still waiting for your reply, could you please help review it?
daniel
Rence, Daniel,
After review the schematic looks good.
It would be best if you could connect sense pins directly to the speaker. If not, the IR drops from the output filter will not be taken into account ant this could affect the IV-sense accuracy.
Regarding the boost inductor, please make sure to at least keep it as described in table 128 from data sheet.
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
Hi Ivan,
I will send you the layout file and could you provide the review comments here?
Thanks!
Hi Zoe,
Are these different than the ones provided in this entry?: https://e2e.ti.com/support/audio/f/6/p/895514/3311088#3311088
-Ivan Salazar
I'm closing this thread due to inactivity. If you have any further questions please reply or create a new thread.
-Ivan Salazar
