Other Parts Discussed in Thread: TPA3110D2-Q1, TPA3111D1-Q1
Hi team,
Do we have audio amplifier that could support 600ohm load impedance, 125mW output power, analog input, differential output? with temp. range of -40C -- +85C.
Thanks.
Hi team,
Thanks.
You may take a look at TPA3111D1-Q1 for mono channel, or TPA3110D2-Q1 for stereo application. Thanks!
Sam
Hi Sam,
Is TPA3111D1-Q1 could support 600ohm output impedance? And how about the THD+N performance when it output 125mW with 600ohm speaker?
Thanks.
Hi Fery,
Theoretically, class-d amp only have the minimum loading limitation because of current capability considerations. To output 125mW, V^2/2/600=0.0125, you will need a >12.2V PVDD. TPA311X device can support this PVDD range. I would suggest you to use a >14V PVDD to avoid voltage clipping.
For the THD+N, you may take a reference to the datasheet plot. Basically we can expect better THD+N performance than 4/6/8R loading condition.
BTW, could you tell me what's the 600ohm loading is?
Thanks!
Sam
Hi Sam,
Is that possible for TPA311x to have line out? The 600ohm loading is PMA6000B equipment.
Thanks!
