Hi team.
In the EVM user guide of TAS5731M, I see the bootstrap cap is 0.0033uF. If it's OK to use 0.022uF、50V, X7R? How can you evaluate the capacitance is proper?
thanks a lot.
Yang
Hi team.
thanks a lot.
Yang
It's recommended to follow our recommendation to use a 33nF cap.
This the charge held by bootstrap cap is used to power the high side driver. The cap discharged when HS FET turns on and get re-charged when LS turns on. In hard clipping conditions, HS keeps ON in multi cycles, BST cap is needed to hold the voltage above BST undervoltage threshold to make the FET driver working well.
Sam
Hi Sam,
Got it. I will forward your suggestion to customer.
thanks a lot.
Yang
Hi Sam,
I know the function of the bootstrap, but I have no the 0.033uF in our material library. We have 0.022uF, X7R,50V or 0.047uF,X7R, 25V. If so, which on would you prefer to use?
Besides, if we pass the AUDIO performance, thermal test and EMI test using 0.022uF, can we use the 0.022uF,X7R,50V in MP stage?
Xiaohui
