PCM2906C: Grounding Requirements
Part Number: PCM2906C
Should all ground pins on the codec be tied to the same net? I have an audio ground that runs off my amplifer and I was thinking to tie the analog grounds of the codec here, but couldn't tell from the block diagrams how the digital and analog grounds are internally connected within the IC. The eval board and datasheet all appear to show these lines all tied to the same ground.
