How to connect 2 TAS5634 devices, output 1200W in PBTL mode
Hi Noki,
For PBTL configuration, you can refer Figure 24 in datasheet.
Derek
Hi Ian,
This is not a common case, I'm not sure if there will be any unexpected issue. To achieve this, you will need to, connect the two TAS5634 devices' output in post filter PBTL mode.
Sam
Hi lan,
The diagram is not visible on this page, can you attach it again?
Sam
There is only one PWM input pair. I corrected the diagram as below,
For other settings, just follow the PBTL configurations in Figure 29 on datasheet.
Please note that this is not a typical case within TI spec/application. Although we don't see any problem till now, we can't guarantee it would work without any problem.
Thanks!
Sam
